[postgis-users] Bad plan without && operator
Nicolas Ribot nicolas.ribot at gmail.com
Thu Dec 7 00:24:24 PST 2017
Same with a logged table.
It seems the && condition have to be duplicated for the right plan to be
chosen:
EXPLAIN SELECT p.id, b.id
FROM tmp.tp1 p join ref.batiment b
    on b.geom && p.geom and p.geom && b.geom and _st_intersects(b.geom,
p.geom);
On 6 December 2017 at 22:36, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> If you change the small table into a normal table (not unlogged) does
> the problem go away? Could be an interesting side effect of
> "unlogged"?
> On Wed, Dec 6, 2017 at 1:14 PM, Nicolas Ribot <nicolas.ribot at gmail.com>
> wrote:
> > Yes, tables are analyzed.
> > I tried reverting argument, same plan generated:
> > FROM tmp.tp1 p join ref.batiment b on st_intersects(p.geom, b.geom);
> > QUERY PLAN
> > Nested Loop  (cost=0.15..21819347.50 rows=50019 width=35)
> >   ->  Seq Scan on batiment b  (cost=0.00..2238826.04 rows=45794904
> > width=193)
> >   ->  Index Scan using tp1_geom_gist on tp1 p  (cost=0.15..0.42 rows=1
> > width=276)
> >         Index Cond: (geom && b.geom)
> >         Filter: _st_intersects(geom, b.geom)
> > Nico
> > On 6 December 2017 at 19:14, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> >> Just invert the arguments in your call to ST_Intersects().
> >> I don't think we have any way to tell the planner anything about which
> >> side of the condition should drive the nested loop join. And yet it
> >> seems to get the "right" one most of the time. I assume you've already
> >> run 'ANALYZE' and the stats are all up-to-date.
> >> P.
> >> On Wed, Dec 6, 2017 at 9:57 AM, Nicolas Ribot <nicolas.ribot at gmail.com>
> >> wrote:
> >> > Hi,
> >> > I have 2 tables, indexed and analyzed.
> >> > One big (batiment) with 45M records, one small (tmp.tp1), with 83k
> >> > records
> >> > (UNLOGGED table)
> >> > When performing a spatial join, the planner chooses the smallest table
> >> > for
> >> > seq scan only if I add a && condition with st_intersects:
> >> > FROM tmp.tp1 p join ref.batiment b on st_intersects(b.geom, p.geom);
> >> > QUERY PLAN
> >> > width=193)
> >> > width=276)
> >> >         Index Cond: (b.geom && geom)
> >> >         Filter: _st_intersects(b.geom, geom)
> >> > vs
> >> > FROM tmp.tp1 p join ref.batiment b on p.geom && b.geom and
> >> > QUERY PLAN
> >> > Nested Loop  (cost=0.42..118443.25 rows=1 width=35)
> >> >   ->  Seq Scan on tp1 p  (cost=0.00..842.75 rows=13675 width=276)
> >> >   ->  Index Scan using batiment_geom_gist on batiment b
> >> > (cost=0.42..8.59
> >> > rows=1 width=193)
> >> >         Index Cond: ((p.geom && geom) AND (geom && p.geom))
> >> >         Filter: _st_intersects(geom, p.geom)
> >> > PG:
> >> > PostgreSQL 9.6.6 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
> >> > 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609, 64-bit
> >> > Postgis:
> >> > POSTGIS="2.3.3 r15473" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.2,
> >> > 08
> >> > September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
> >> > LIBJSON="0.11.99" TOPOLOGY (topology procs from "2.3.2 r15302" need
> >> > upgrade)
> >> > RASTER
> >> > Thanks for any hint.
> >> > Nicolas
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > postgis-users at lists.osgeo.org
> >> > https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171207/40b5d305/attachment.html>
