[postgis-users] st_geojson like st_mvt function
Regina Obe lr at pcorp.us
Wed Dec 13 01:59:27 PST 2017
This has come up in discussion before and we have a ticket for it.
https://trac.osgeo.org/postgis/ticket/1833
I've revised the title so intent is clearer and easier to find for any others looking for it.
I think Paul Ramsey intimated he may do it for PostGIS 2.5, but that's still an iffy for him since I think he's got higher priorities.
If enough interest it will probably happen in 2.5 since I think much of the logic can be patterned after ST_AsMVT.
Feel free to add your comments to the above ticket or provide a patch or garner funding for it.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of RĂ©mi Desgrange
Sent: Tuesday, December 12, 2017 3:56 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] st_geojson like st_mvt function
this is my first mail on this list, I didn't know if I should have posted on dev list or this one. Don't hesitate to correct.
With postgis 2.4 we now have the possibility to generate mvt format directly in SQL, what I really like is the ability to construct a mvt response with geometrie + data. The sql result is directly well formated and ready to use. When I need to use geojson in my app I need something like that :
{ "type": "Feature",
  "geometry":
        "type": "Point",
        "coordinates": [125.6, 10.1]
      "properties": { "name": "Dinagat Islands" }
In order to do that I do :
SELECT name, st_geojson(geom) as geom FROM mytable
And then I my code I manipulate "name" to put it in the json under "properties" there hack around to directly return geojson, but they're hack not actual solutions.
What I imagine is something like that :
SELECT st_geojson(x) FROM (SELECT name, geom FROM mytable) x
the signature would be :
text St_AsGeoJSON(anyelement set row)
I do not know if this question has already been asked, I found nothing when I googled. Do you think that this is a legitimate feature request ?
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171213/61e132aa/attachment.html>
