[postgis-users] Geography point to polygon st_distance for a polygon crossing the equator
Paul Ramsey pramsey at cleverelephant.ca
Sun Feb 19 19:56:54 PST 2017
I don't the polygon you've draw means what you think it does.
POLYGON((-90 -80, 90 -80, 90 10, -90 10, -90 -80))
For example, you probably figure the first segment, -90 -80, 90 -80 runs
east-west between two points close to the south pole. In fact, it runs
directly over the south pole, so actually to the south of your point of
interest.
P
On Sun, Feb 19, 2017 at 7:36 PM, Sebastien Delaux <s.delaux at metocean.co.nz>
wrote:
> Hi all,
> I am new to postgis and I am interested in finding all the points that are
> located at x metres or less of a polygon that are stored in my postgres
> database.
> As I am working with data located all over the world and want to work with
> distances in metres I decided to use the geography type.
> I am trying to understand why the following query returns 0 when the point
> is clearly not included in the polygon:
> SELECT ST_Distance(ST_GeographyFromText('SRID=4326;POINT(0.
> -82.)'),ST_GeographyFromText('SRID=4326;POLYGON((-90 -80, 90 -80, 90 10,
> -90 10, -90 -80))'));
> I suspect this has something to do with the polygon crossing the equator
> as
> -82.)'),ST_GeographyFromText('SRID=4326;POLYGON((-90 -80, 90 -80, 90 -10,
> -90 -10, -90 -80))'));
> returns a plausible distance.
> Would anybody know whether my polygon is violating some assumption or
> whether there is any other reason that I am getting those results?
> Thanks
> Sebastien
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170219/4cb6a050/attachment.html>
