[postgis-users] Understanding 3d bbox filtering support
Andrea Aime andrea.aime at geo-solutions.it
Thu Jan 19 07:42:08 PST 2017
Ah, thanks Paul, that works
Cheers
Andrea
On Thu, Jan 19, 2017 at 4:32 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> No, just construct a 3D geometry as your query filter, not a 3d box.
> select count(*) from "3dfloor" where geom &&& ST_Makeline(ST_MakePoint(0,0,
> 0), ST_MakePoint(1000000,1000000,1));
> I would imagine that should work fine and dodge this little nastiness.
> P
> On Thu, Jan 19, 2017 at 5:14 AM, Andrea Aime <andrea.aime at geo-solutions.it
> > wrote:
>> On Wed, Jan 18, 2017 at 5:13 PM, Rémi Cura <remi.cura at gmail.com> wrote:
>>> Hey,
>>> I can't test right now,
>>> but :
>>>  - you have the same srid for object and bbox right?
>> Err... the box3d does not seem to have a srid, nor I could find a way to
>> assign one.
>>>  - I remember Sandro discussing this case
>> I searched in postgis-users before sending and again now, but could not
>> find any.
>> I've now searched in postgis-devel and found a thread you started on the
>> topic instead:
>> http://osgeo-org.1560.x6.nabble.com/BOX3D-strange-behaviour-
>> td5251231.html
>> So... it seems that the z gets dropped eh? I see a pull request to fix it
>> but it seems it has
>> been closed and the associated ticket marked as "wont' fix":
>> https://trac.osgeo.org/postgis/ticket/3466
>> Soo... should I do 2d filtering using && and then do the z filtering
>> using ST_Zmin/ST_ZMax?
>> Cheers
>> Andrea
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Andrea Aime
>> @geowolf
>> Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>> mob: +39  339 8844549 <+39%20339%20884%204549>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170119/cf87b0f3/attachment.html>
