[postgis-users] St_AsEwkt
Olivier Leprêtre o.lepretre at gmail.com
Wed Jul 5 10:54:41 PDT 2017
I'm using pgplsql to calculate shortest distance between points. This works
but I'm wondering if my code is optimized because I'm using many ST_AsEwkt.
sqls='SELECT id code,ST_AsEwkt(ST_StartPoint(the_geom)) as
geom1,ST_AsEwkt(ST_EndPoint(the_geom)) as geom2 FROM ' || schem ||
'.trench';
FOR row IN
            EXECUTE (sqls)
LOOP
            sqls1='SELECT id
code1,ST_Distance(ST_AsEwkt(the_geom),St_AsEwkt(''%2$s'')) FROM %1$s.nodes
order by ST_Distance(ST_AsEwkt(the_geom),ST_AsEwkt(''%2$s'')) LIMIT 1';
            sqls1=format(sqls1,schem,row.geom1);
            FOR row1 IN
                        EXECUTE (sqls1)
Would it be possible to have a smarter syntax with less ST_AsEwkt ?
Thanks,
Olivier
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170705/eaba3a1e/attachment.html>
