[postgis-users] TR: St_AsEwkt
Felix Kunde felix-kunde at gmx.de
Thu Jul 6 04:04:59 PDT 2017
in general, don't use FOR loops if you just want to iterate over query results. You can do that with plain SQL (or SQL function). You could try out the LATERAL construct if you have FOR EACH use cases.
Cheers
Felix
Betreff: [postgis-users] TR: St_AsEwkt
Yes, you're certainly right, there must be other way of doing that, it's an old bigger script which I was revisiting. I just extracted a small part of it. It uses pgplsql because the purpose is to create tables of results. Using st_AsEwkt was the only way I found to get geometry from a loop and pass it in another loop.
Thanks,
Olivier
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Tom van Tilburg
Envoyé : jeudi 6 juillet 2017 10:55
À : PostGIS Users Discussion
Objet : Re: [postgis-users] St_AsEwkt
Somehow I feel there is no need for plpgsql in what you are doing and that indeed the ST_AsEwkt is too much.
I can't wrap my head around what this script is exactly trying to do though. Can you elaborate a bit on your use-case? What is the original data and what would you like to know from it?
Best,
 Tom
On Wed, Jul 5, 2017 at 7:54 PM, Olivier Leprêtre <o.lepretre at gmail.com[mailto:o.lepretre at gmail.com]> wrote:
I'm using pgplsql to calculate shortest distance between points. This works but I'm wondering if my code is optimized because I'm using many ST_AsEwkt.
sqls='SELECT id code,ST_AsEwkt(ST_StartPoint(the_geom)) as geom1,ST_AsEwkt(ST_EndPoint(the_geom)) as geom2 FROM ' || schem || '.trench';
FOR row IN
            EXECUTE (sqls)
LOOP
            sqls1='SELECT id code1,ST_Distance(ST_AsEwkt(the_geom),St_AsEwkt(''%2$s'')) FROM %1$s.nodes order by ST_Distance(ST_AsEwkt(the_geom),ST_AsEwkt(''%2$s'')) LIMIT 1';
            sqls1=format(sqls1,schem,row.geom1);
            FOR row1 IN
                        EXECUTE (sqls1)
Would it be possible to have a smarter syntax with less ST_AsEwkt ?
Thanks,
Olivier
[https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient]
Garanti sans virus. www.avast.com[https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient]
postgis-users mailing list
postgis-users at lists.osgeo.org[mailto:postgis-users at lists.osgeo.org]
https://lists.osgeo.org/mailman/listinfo/postgis-users
_______________________________________________ postgis-users mailing list postgis-users at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/postgis-users[https://lists.osgeo.org/mailman/listinfo/postgis-users]
