[postgis-users] compiling from source code
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jul 7 11:09:21 PDT 2017
I get the same error running on Ubuntu 16.04 with:
$ gcc -V
gcc: error: unrecognized command line option ā€˜-Vā€™
gcc: fatal error: no input files
compilation terminated.
Looks like the option should be --version
$ gcc --version
gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-Steve
On 7/7/2017 1:51 PM, Sandeep Gupta wrote:
> Hi,
> I am using gcc version 5.3 to compile postgis on Fedora.
> The compile  fails at the configure step.
> I get the error:
> configure: error: C preprocessor "gcc" fails sanity check
> See `config.log' for more details
> The relevant line in config.log:
> configure:3031: gcc -v >&5
> Reading specs from
> /home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/lib/gcc/x86_64-unknown-linux-gnu/5.3.0/specs
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0/libexec/gcc/x86_64-unknown-linux-gnu/5.3.0/lto-wrapper
> Target: x86_64-unknown-linux-gnu
> Configured with: ../configure
> --prefix=/home/linuxbrew/.linuxbrew/Cellar/gcc/5.3.0
> --enable-languages=c,c++,objc,obj-c++,fortran --program-suffix=-5
> --with-gmp=/home/linuxbrew/.linuxbrew/opt/gmp
> --with-mpfr=/home/linuxbrew/.linuxbrew/opt/mpfr
> --with-mpc=/home/linuxbrew/.linuxbrew/opt/libmpc
> --with-isl=/home/linuxbrew/.linuxbrew/opt/isl --with-system-zlib
> --enable-libstdcxx-time=yes --enable-stage1-checking
> --enable-checking=release --enable-lto
> --with-build-config=bootstrap-debug --disable-werror
> --with-pkgversion='Homebrew gcc 5.3.0'
> --with-bugurl=https://github.com/Homebrew/homebrew/issues
> --enable-plugin --disable-nls --disable-multilib
> Thread model: posix
> gcc version 5.3.0 (Homebrew gcc 5.3.0)
> configure:3042: $? = 0
> configure:3031: gcc -V >&5
> gcc: error: unrecognized command line option '-V'
> It seems gcc does not like "-V" option. I this a issue to with later
> gcc versions?
> Thanks.
> sandeep
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
