[postgis-users] <-> operator does not return true distance
Regina Obe lr at pcorp.us
Thu Jul 13 13:50:56 PDT 2017
Jakob,
Did you upgrade your install from an older version say 9.4.
I think if you did a pg_upgrade, and didn't do a ALTER EXTENSION postgis.
after upgrade, this would explain your issue since the operators would not
get upgraded.
On my PostGIS 2.3.2, 9.6 behavior is as expected.  Unfortunately I don't
have 2.2.2 lying around at moment.
Also there was an ordering bug I think in 2.2 early version that may have
caused this.  If that is your issue, then output of <-> would be real even
though ordering is wrong.
Try this query:
SELECT id,
       ST_Distance(my_point.geom,
                   my_polygons.geom) AS real_distance,
                   ST_Centroid(my_polygons.geom)) AS centroid_distance,
my_point.geom <-> my_polygons.geom
FROM (
    SELECT 'blue' AS id, ST_Polygon(ST_GeomFromText('LINESTRING(0 3, 2 3,  2
4, 0 4 ,0 3)'),4326) AS geom
    UNION
    SELECT 'green' AS id,  ST_Polygon(ST_GeomFromText('LINESTRING(2 0, 8 0 ,
8 2, 2 2 ,2 0)'),4326) AS geom
) AS my_polygons,
    SELECT ST_SetSRID(ST_Point(1, 1),4326) AS geom
) AS my_point
ORDER BY my_point.geom <-> my_polygons.geom
-- output should be --
  id   | real_distance | centroid_distance | ?column?
green |             1 |                 4 |        1
blue  |             2 |               2.5 |        2
(2 rows)
Hope that helps,
Regina
http://postgis.us
http://www.paragoncorporation.com
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Jakob Miksch
Sent: Thursday, July 13, 2017 4:27 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] <-> operator does not return true distance
(I asked a similar question here
https://gis.stackexchange.com/questions/247034/postgis-operator-does-not-ret
urn-true-distance )
I used the <-> operator with PostGIS 2.2.2 and PostgreSQL 9.5.7 .
According to the docs
(http://postgis.net/docs/manual-2.2/geometry_distance_knn.html) the <->
operator should order by "true KNN distance" and *not* by "centroid
distance".
However it does not work for me. See the minimal example below:
( illustration:  https://i.stack.imgur.com/QZA6D.png )
SELECT id,
FROM (
    UNION
) AS my_polygons,
) AS my_point
--- obtained Result:
| blue  |       2       |        2.5        |
| green |       1       |        4          |
(I expected the rows to be in the opposite order)
Apparently the <-> operator orders by the centroid_distance and not by the
real_distance, even though the docs say: "[...] for PostgreSQL 9.5+, does
true KNN distance search giving true distance between geometries [...]"
I tried the same example on 2.3.2 and PostgreSQL 9.5.7 and I get the
expected result (which orders by "real_distance").
So, for me it seems that ordering by "real_distance" with the <-> operator
does not work with PostGIS 2.2.2 - but this is *not* written in the docs.
Can you reproduce this behaviour? Or did I understand/make something wrong
here?
Thanks and best regards,
Jakob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170713/ff96797c/attachment.html>
