[postgis-users] table creation and mixed geometries
Regina Obe lr at pcorp.us
Fri Jul 28 19:56:14 PDT 2017
Tom,
a) geom geometry   means no restriction whatsoever.  No typmod is applied.
b) geometry typmod is short for any 2D geometry so it won't allow Zs.
c) If you want to allow only 3D geometries, then what you'd want is
geom geometryZ
create table testptz (pkey integer primary key, geom geometry(geometryZ));
There is no reason to include a srid constraint unless you plan to enforce it.  Though putting 0 in there is same as leaving it out.
Hope that helps,
Regina
http://postgis.us
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Kralidis, Tom (EC)
Sent: Friday, July 28, 2017 1:04 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] table creation and mixed geometries
Hi all: as per [1] we are looking into how GeoAlchemy2 [2] communicates with PostGIS when creating columns of type geometry.  Below are two variations of table creation/geometry column definition:
a./ create table testptz (pkey integer primary key, geom geometry);
b./ create table testptz (pkey integer primary key, geom geometry(geometry, 0));
The issue/context is being able to insert both POINT and POINTZ geometries into a given table.
GeoAlchemy runs the SQL in option b to create the table but runs into error when trying to insert as follows:
insert into testptz values (1, 'POINT(0 0 0)');
ERROR: Geometry has Z dimension but column does not
When running the insert command against option a, everything works.  Any idea/suggestions?
Thanks
..Tom
[1] https://groups.google.com/forum/#!topic/geoalchemy/LxC9y2JsXhg
[2] https://geoalchemy-2.readthedocs.io/en/latest/
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
