[postgis-users] clone schema - pg_get_serial_sequence returns null
Regina Obe lr at pcorp.us
Mon Jul 31 02:09:38 PDT 2017
I think you'd have better luck asking this on pgsql-general news list.
https://www.postgresql.org/list/pgsql-general/
There is no PostGIS related question here.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Olivier Leprêtre
Sent: Sunday, July 30, 2017 2:24 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] clone schema - pg_get_serial_sequence returns null
I want to clone a schema, so I wrote the script below. My problem is that I
can’t get sequences with pg_get_serial_sequence for the cloned primary keys.
The sequence seems to be ok in the cloned schema :
  idapp integer NOT NULL DEFAULT nextval('pr_1_1.ptbt_idapp_seq'::regclass),
  CONSTRAINT adn_ptbt_pkey PRIMARY KEY (idapp)
But if I run select pg_get_serial_sequence('pr_1_1.ptbt', 'idapp') it
returns <NULL>
Conversely, running pg_get_serial_sequence('source.ptbt', 'idapp') (from the
source schema) returns the correct sequence.
I’m using 9.6, I saw that it could be a problem because column is not
directly as “serial”, is this an answer without solution ?
Any help will be appreciated !
Thanks,
Olivier
CREATE OR REPLACE FUNCTION params.prm_colne_schema(source_schema text,
dest_schema text) RETURNS boolean AS
$BODY$
DECLARE
  object text;
  buffer text;
  default_ text;
  column_ text;
  sqls text;
BEGIN
            IF dest_schema <> 'public' THEN
                        EXECUTE 'DROP SCHEMA if exists ' || dest_schema || '
CASCADE';
                        EXECUTE 'CREATE SCHEMA ' || dest_schema;
            END IF;
            -- copy sequences
            FOR object IN
                        SELECT sequence_name::text FROM
information_schema.SEQUENCES WHERE sequence_schema = source_schema
            LOOP
                        EXECUTE 'CREATE SEQUENCE ' || dest_schema || '.' ||
object;
            END LOOP;
            -- copy tables without constraints
            FOR object IN
                        SELECT TABLE_NAME::text FROM
information_schema.TABLES WHERE table_schema = source_schema  and
substr(table_name,1,4) <> 'src_'
            LOOP
                        buffer := dest_schema || '.' || object;
                        EXECUTE 'CREATE TABLE ' || buffer || ' (LIKE ' ||
source_schema || '.' || object || ' INCLUDING DEFAULTS)';
                        FOR column_, default_ IN
                                   SELECT column_name::text,
REPLACE(column_default::text, source_schema, dest_schema) FROM
information_schema.COLUMNS WHERE table_schema = dest_schema AND TABLE_NAME =
object
                        LOOP
                                   EXECUTE 'ALTER TABLE ' || buffer || '
ALTER COLUMN ' || column_ ||' DROP NOT NULL;';
                        END LOOP;
            END LOOP;
            -- copy tables with constraints
            FOR object IN
substr(table_name,1,4) = 'src_'
            LOOP
source_schema || '.' || object || ' INCLUDING ALL)';
                        -- copy sequences
object AND column_default LIKE 'nextval(%' || source_schema ||
'%::regclass)'
                        LOOP
                                   sqls='ALTER TABLE ' || buffer || ' ALTER
COLUMN ' || column_ || ' SET DEFAULT ' || default_;
                                   RAISE NOTICE 'default=%',sqls;
                                   EXECUTE (sqls);
                        END LOOP;
            END LOOP;
            RETURN true;
EXCEPTION
            WHEN others THEN
            RETURN false;
END;
$BODY$
LANGUAGE plpgsql VOLATILE;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170731/92bcb16c/attachment.html>
