[postgis-users] Newbie - Help with PGRouting
Benjamin Orpilla Benjamin.Orpilla at downer.co.nz
Sun May 21 13:30:41 PDT 2017
Hi all,
I am new at using PostGreSQL/PostGIS. I am wanting to run a routing analysis and found the documentation at the PGRouting site with links to downloads here. However, I am overwhelmed by the number of build and what to actually download and install on my machine. Any guidance would be much appreciated.
Cheers,
Benjie
Benjamin Orpilla
Asset Information Manager
New Zealand
[cid:image001.jpg at 01D2D2D5.AF8F0B20]<http://www.downergroup.co.nz/>
M | +64277068599
E | Benjamin.Orpilla at downer.co.nz
133 Main South Rd
Dunedin
www.downergroup.co.nz<http://www.downergroup.co.nz>
www.downercareers.co.nz
[cid:image002.png at 01D2D2D5.AF8F0B20]   Think before you print
Note:
This message is for the named person's use only. It may contain confidential,
 proprietary or legally privileged information. If you receive this message
 in error, please immediately delete it and all copies of it from your
 system, destroy any hard copies of it and notify the sender. You must not,
 directly or indirectly, use, disclose, distribute, print, or copy any part
 of this message if you are not the intended recipient. No confidentiality
 or privilege is waived or lost by any such mis-transmission or error.
Downer reserves the right to monitor all e-mail communications through its
 networks. Any views expressed in this message are those of the individual
sender, except where the message states otherwise and the sender is
 authorized to state them to be the views of any such entity.
Downer includes Downer New Zealand Limited and Hawkins 2017 Limited and
 their related and associated companies.
______________________________________________________________________________
This email has been filtered by SMX.
For more information visit http://smxemail.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170521/0c1f78a6/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170521/0c1f78a6/attachment.jpg>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170521/0c1f78a6/attachment.png>
