[postgis-users] [XX000] ERROR: AddToPROJ4SRSCache: could not parse proj4 string
Andrew Joseph ap.joseph at live.com
Fri Nov 10 15:33:08 PST 2017
SELECT ST_AsText(ST_Transform(ST_Transform(ST_SetSRID(ST_Point(-97.353287,
31.105862), 4326), 2277),4326));
produces "POINT(-97.353287 31.1058619999995)" - so it appears to work
The table srid for both concerete and foreign tables shows as 2277.
Using st_transform(st_setsrid(geom,2277),4326) on the foreign table fails as
well.
I've tried reverting my configuration back as far as possible (2.3.2 breaks
on postgres 10+):
"POSTGIS="2.3.4 r16009" GEOS="3.6.2-CAPI-1.10.2 4d2925d6" SFCGAL="1.3.0"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.0, released 2017/04/28"
LIBXML="2.9.3" LIBJSON="0.11.99" TOPOLOGY RASTER"
This leads me to believe that either something is wrong with my PROJ
configuration, as Paul suggested, or that something has been fundamentally
broken between proj4.8 and proj4.9. Should I be able to rely on the standard
Ubuntu 16.04 PROJ libraries? I've built 4.9.3 from source and also tried
using standard packages:
apt-get install libproj9 libproj-dev proj-data proj-bin
Both installations result in the same issue. Am I missing a critical
package, or is there environment variable that needs to be set for PROJ to
work properly with postgis?
Sent from: http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html
