[postgis-users] [XX000] ERROR: AddToPROJ4SRSCache: could not parse proj4 string
Andrew Joseph ap.joseph at live.com
Wed Nov 15 12:15:21 PST 2017
After days of trial and error, I solved this by compiling GDAL with
--with-static-proj4=/usr/local. Turns out the current version of the  ESRI
filegeodatabase API
https://github.com/Esri/file-geodatabase-api/tree/master/FileGDB_API_1.5.1
unexpectedly and infuriatingly embeds PROJ4 in one of its .so files which
conflicts randomly with the installed PROJ4 version!
See
http://osgeo-org.1560.x6.nabble.com/gdal-dev-compiling-gdal-with-esri-file-gdb-td5311469.html
for more info.
That's what I get for using a closed source ESRI lib with GDAL I suppose!
Sent from: http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html
