[postgis-users] [XX000] ERROR: AddToPROJ4SRSCache: could not parse proj4 string
Andrew Joseph ap.joseph at live.com
Thu Nov 16 10:36:43 PST 2017
As of yesterday GDAL will now throw an error at configure if
--with-static-proj4 is not enabled when ESRI FGDB is installed -so hopefully
I'll be the last person to have this issue.
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Enable-with-static-proj4-by-default-if-ESRI-FGDB-option-is-given-on-Linux-td5342780.html
Sent from: http://postgis.17.x6.nabble.com/PostGIS-User-f3516033.html
