[postgis-users] Large 3D triangluar meshes - good fit?
Eric knacktus at googlemail.com
Sun Nov 26 00:27:42 PST 2017
Hi all,
I'm completely new to PostGIS and spatial DBs, but not to Postgres. I've
scanned the docs and saw that PosGIS can do a lot, but that it also
needs some proper learning.
So, before I dive into PostGIS, I'd like to ask you about your opinion.
How good does PostGIS fit in the following use-case?
- objects of large 3D triangular meshes; up to 50 000 triangles per object
- up to 10 000 objects in a scene
- overall about 50 000 000 triangles in a scene
- get all objects inside a volume (box, cube and capped pyramid - like a
frustum) - based on the bounding box
- get all triangles inside a volume, where the triangles can be filtered
prior this check.
- order triangles by coordinate
Performance does matter. Queries should be roughly in the order of ~ 100
ms. (I have absolutely no idea if this is realistic ...). Available
infrastructure is quite capable (128 GB ram 16 Cores).
Thanks and best regards,
Jan
