[postgis-users] How can I update proj4 without recompile
Guido Stein gstein at appgeo.com
Wed Nov 29 08:38:29 PST 2017
Thanks for the input.
I really appreciate it.
-guido
On Tue, Nov 28, 2017 at 5:10 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Hi Guido,
> Knowing your use case ("wanting to avoid bad area calculations in
> geodetics"), I can say definitively that you're out of luck. Just
> replacing the library file won't do the trick, as the code in PostGIS
> that uses the new proj geodetic area calculations won't be activated
> with anything less than a rebuild.
> ATB,
> P
> On Tue, Nov 28, 2017 at 9:59 AM, Guido Stein <gstein at appgeo.com> wrote:
> > Hey folks,
> > I am trying to update the proj4 libraries on my postgis because I think
> the
> > older version of proj4 is giving me faulty areas (known bug). I would
> like
> > to go from 4.8 to 4.9.
> > In talking to some friends I found out that I can make a sym link from
> the
> > existing proj4 to a newly compiled proj4 without an issue. But, I can't
> seem
> > to figure that out completely and need a little help.
> > # Here is what is running on my system:
> > select version();
> >     PostgreSQL 9.5.10 on x86_64-pc-linux-gnu, compiled by gcc (Ubuntu
> > 4.8.4-2ubuntu1~14.04.3) 4.8.4, 64-bit
> > select postgis_full_version();
> >     POSTGIS="2.3.3 r15473"
> >     GEOS="3.4.2-CAPI-1.8.2 r3921"
> >     PROJ="Rel. 4.8.0, 6 March 2012"
> >     GDAL="GDAL 1.10.1, released 2013/08/26"
> >     LIBXML="2.9.1"
> >     LIBJSON="0.11.99"
> >     RASTER
> > # here is what I have done so far:
> > - locate the directory of the postgis
> >     pg_congif --pkglibdir
> > - get information about what libraries are associated with postgis
> >     ldd postgis-2.3
> >         libproj.so.0 => /usr/lib/libproj.so.0 (0x00007ff19e1dd000)
> > # this is where I loose the thread
> > I don't know if when I make install if there should be a file I need to
> link
> > here?? Yeah I need a clue and would be grateful for any assistance on
> this.
> > -guido
> > This e-mail message and any attachments may contain confidential or
> legally
> > privileged information. If you are not an intended recipient or otherwise
> > authorized to receive this message, you should not use, copy, distribute,
> > disclose or take any action based on the information contained in this
> > e-mail or any attachments. If you have received this message and
> material in
> > error, please advise the sender immediately by reply e-mail and delete
> this
> > message. Thank you on behalf of Applied Geographics, Inc. (AppGeo).
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
This e-mail message and any attachments may contain confidential or legally
e-mail or any attachments. If you have received this message and material
in error, please advise the sender immediately by reply e-mail and delete
this message. Thank you on behalf of Applied Geographics, Inc. (AppGeo).
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20171129/13d9b4ad/attachment.html>
