[postgis-users] Strange behavior with empty geometries GROUP BY
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Sep 11 12:53:54 PDT 2017
What is the operator used by GROUP BY?
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Regina Obe
Envoyé : 11 septembre 2017 15:42
À : 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Objet : Re: [postgis-users] Strange behavior with empty geometries GROUP BY
Hmm interesting.  I was about to say they probably have the same bounding box but they don't quite according to box2d.  Perhaps our box2d returns float4 but our internal box is double precision?
I don't know.
WITH polys AS (
  SELECT 1 id, ST_GeomFromText('MULTIPOLYGON(((251000 5243597.61702128,
                                               251038 5243558,
                                               251056 5243527,
                                               251057.227272727 5243500,
                                               251000 5243500,
                                               251000 5243597.61702128)),
                                             ((251021 5243690,
                                               251000 5243681.87096774,
                                               251000 5243750,
                                               251250 5243750,
                                               251250 5243749.86206897,
                                               251196 5243694,
                                               251168 5243687,
                                               251021 5243690)))') geom
  UNION ALL
  SELECT 2 id, ST_GeomFromText('POLYGON((251000 5243681.87096774,
                                         251021 5243690,
                                         251168 5243687,
                                         251196 5243694,
                                         251250 5243598.15,
                                         251167.008064516 5243500,
                                        251056 5243527,
                                         251038 5243558,
                                         251000 5243681.87096774))') geom
SELECT BOX2D(geom)
FROM polys;
BOX(251000 5243500,251250 5243750)
BOX(251000 5243500,251250 5243749.86206897)
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Pierre Racine
Sent: Monday, September 11, 2017 3:08 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: Re: [postgis-users] Strange behavior with empty geometries GROUP BY
I get a similar bug but now with full pledged geometries. Those two polygons, though very different, GROUP BY together. Which mysterious PostGIS operator is used by GROUP BY and make those two polygons equivalent?
  WITH polys AS (
                                               251038 5243558,
                                               251056 5243527,
                                               251000 5243500,
                                             ((251021 5243690,
                                               251000 5243750,
                                               251250 5243750,
                                               251196 5243694,
                                               251168 5243687,
  UNION ALL
                                         251021 5243690,
                                         251168 5243687,
                                         251196 5243694,
                                         251250 5243598.15,
                                         251056 5243527,
                                         251038 5243558,
) SELECT ST_AsText(geom)
  FROM polys
  GROUP BY geom;
Pierre
De : postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Pierre Racine
Envoyé : 29 juin 2017 15:42
À : PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Much better...
Envoyé : 23 juin 2017 23:26
À : 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Pierre,
Thanks for pointing out the issue.  Sandro has fixed the problem
https://trac.osgeo.org/postgis/ticket/3777#comment:17
Can you try with your larger workload.  If you happen to have a windows box, 64-bit  pre-compiled binaries here:
http://postgis.net/windows_downloads/
(I have 32-bit building turned off at moment cause it errors out on the gui tests and haven't had a chance to troubleshoot).
If you have a patched version:
SELECT postgis_full_version();
Your version should have  r15450 (or above) for PostGIS 2.4 and r15451 (or above)for PostGIS 2.3.
POSTGIS="2.3.3dev r15451" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8" LIBJSON="0.12" RASTER
Thanks,
Regina
Sent: Tuesday, June 20, 2017 5:42 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: [postgis-users] Strange behavior with empty geometries GROUP BY
When I try to count the occurrence of a number of empty geometries like this:
SELECT ST_AsText(geom) txt, count(*)
FROM (
SELECT 'POINT(0 0)'::geometry geom
UNION ALL
UNION ALL
UNION ALL
SELECT 'POINT(0 1)'::geometry geom
UNION ALL
SELECT 'LINESTRING(0 0,0 1)'::geometry geom
UNION ALL
SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry geom
UNION ALL
SELECT 'POINT EMPTY'::geometry geom
) foo
GROUP BY geom;
The 'GEOMETRYCOLLECTION EMPTY' and the 'POINT EMPTY' do not aggregate and I get:
txt        count
POINT(0 0)                                                         2
POINT EMPTY                                                   1
POINT(0 0)                                                         1
LINESTRING(0 0,0 1)                                      1
GEOMETRYCOLLECTION EMPTY                1
POINT(0 1)                                                         1
If I remove any geometry other than the two EMPTY ones like this (I removed the first one 'POINT(0 0)'), the two EMPTY geometries DO aggregate:
FROM (
UNION ALL
UNION ALL
UNION ALL
UNION ALL
UNION ALL
) foo
GROUP BY geom;
Result:
txt                                          count
POINT(0 0)                          2
POINT EMPTY                    2
POINT(0 1)                          1
Any idea why empty geometries aggregation seem so dependent on what others geoms are in the table?
Sorry I could not build a more simple example.
Thanks,
Pierre
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170911/a9416a62/attachment.html>
