[postgis-users] PostgreSQL VS EDB performance with PostGIS
Nicklas Avén nicklas.aven at jordogskog.no
Thu Sep 21 01:39:53 PDT 2017
Hello
This question is not possible to answer without more information like:
Did you have performance problems with PostGIS under PostgreSQL?Why do
you expect better performance from moving to EDB? What functionality in
EDB did you expect to impact the performance?
What is the query that is slow? There are many functions in PostGIS,
what are you using. Most performance problems with PostGIS is related
to not having indexes where needed, or a query written in a way so
PostGIS cannot gain from indexes.
Regards
Nicklas
On Thu, 2017-09-21 at 09:20 +0530, Pradeep Kanth G wrote:
> Hi,
> Recently , I have moved my PostGIS Spatial data from PostgreSQL to
> EDB(Enterprise DB) .After moving into EDB there is no much difference
> between Open Source PostgreSQL performance wise.
> So kindly suggested to us ,how to improve the EDB performance with
> PostGIS.
> Regards
> Pradeep Kanth
> Disclaimer | The information contained in this electronic message
> (including any attachments) is intended for the exclusive use of the
> addressee(s) and may contain confidential or privileged
> information.If you have received this in error, please notify the
> sender immediately and delete the material from your machine. Any
> action including review, retransmission, dissemination of this email
> or the attachments present along with the email by persons or
> entities other than the intended recipient is prohibited.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20170921/c81e5b75/attachment.html>
