[postgis-users] Encoding and Collation Question
Gary Turner g at elizr.com
Sat Apr 7 05:15:45 PDT 2018
IIRC, postgres/gis tables are UTF-8 by default.  That's probably the
best option to use to avoid hassles, and to be more stable long-term.
If you are having problems, I suspect that the issue is what encoding
your source data was/is in, and what process you used to import it.
Can you do it again? What process did you use? Do you know what encoding
it was in?
On 07/04/18 10:05, Aaron Edwards wrote:
> Hi,
> I’m trying to create a spatial layer in GoeServer using postgis.  The
> problem is that there are a few special characters in the name column
> (rivers and streams in New Mexico).  In Zuni river, for example, the N
> has a tilde character over it.  So the labels are all wonky.
> What Encoding and Collation would prevent this?  I tried WIN1252 and
> English_United States.1252, but that prevented me from installing the
> ogr_fdw extension, and that seemed to preclude the use of
> UpdateGeometrySRID(), which I need.
> Thanks.
> Aaron
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180408/55f6da7c/attachment.html>
