[postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Regina Obe lr at pcorp.us
Tue Apr 17 08:45:03 PDT 2018
Jibran,
Given this is not a PostGIS question, you should ask this on pg-general list
instead.
https://www.postgresql.org/list/pgsql-general/
One thought, did you run the installer as an Administrator - Right click -->
Run As Administrator?
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Jibran Khan
Sent: Tuesday, April 17, 2018 7:09 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Unable to install PostgreSQL 9.5.11 on Windows 10
Hello,
Apologies if this is an irrelevant question, here.
I have been trying to install PostgreSQL 9.5.11 on Windows 10 (x64) using
Enterprise DB interactive installer. But, no success.
I keep getting this error.
I am aware about the BigSQL installers but I prefer the Enterprise DB one
I came across the similar issue here:
https://stackoverflow.com/questions/46118851/unable-to-install-postgresql-on
-windows-10
A little googling routed me towards some proposed solutions (here
<http://1stopit.blogspot.dk/2011/01/postgresql-83-and-84-fails-to-install.ht
ml>  and here
<https://serverfault.com/questions/230219/vbscript-wont-run-for-domain-user-
on-windows-server-2008-r2> ).
I tried them but, no success.
Here is the error message, I am getting.
Can somebody suggest the workaround to fix this issue?
Log started 04/17/2018 at 11:28:34
    Preferred installation mode : qt
    Trying to init installer in mode qt
    Mode qt successfully initialized
    Executing
C:\my_user\AppData\Local\Temp/postgresql_installer_676baef523/temp_check_com
spec.bat
    Script exit code: 0
    Script output:
     "test ok"
    Script stderr:
    Could not find registry key
HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Data
Directory. Setting variable iDataDirectory to empty value
HKEY_LOCAL_MACHINE\SOFTWARE\PostgreSQL\Installations\postgresql-x64-9.5 Base
Directory. Setting variable iBaseDirectory to empty value
Service ID. Setting variable iServiceName to empty value
Service Account. Setting variable iServiceAccount to empty value
Super User. Setting variable iSuperuser to empty value
Branding. Setting variable iBranding to empty value
Version. Setting variable brandingVer to empty value
Shortcuts. Setting variable iShortcut to empty value
DisableStackBuilder. Setting variable iDisableStackBuilder to empty value
    [11:28:39] Existing base directory:
    [11:28:39] Existing data directory:
    [11:28:39] Using branding: PostgreSQL 9.5
    [11:28:39] Using Super User: postgres and Service Account: NT
AUTHORITY\NetworkService
    [11:28:39] Using Service Name: postgresql-x64-9.5
    Executing cscript //NoLogo
"C:\my_user\AppData\Local\Temp\postgresql_installer_676baef523\prerun_checks
.vbs"
    Script exit code: 1
    Script output:
     CScript Error: Loading script
.vbs" failed (Access is denied. ).
    Script stderr:
     Program ended with an error exit code
    Error running cscript //NoLogo
.vbs": Program ended with an error exit code
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180417/891abf8c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180417/891abf8c/attachment.png>
