[postgis-users] Adaptive k-nearest neigbourh in PostGIS
Vilem Ded Ded.V at seznam.cz
Mon Jan 8 07:26:15 PST 2018
Thanks,
very nice indeed! I will definitely give that a try.
But this is really very dependent on data distribution. My dataset is
clustered so it will be better, but probably not good enough:/
As I understood KNN in Postgis is implemented with priority queue?
If so, there must be condition of type while i < k {next} , where k is our K
in KNN. I was hoping for some way how to alter this part of code - "just"
change those few lines..
Thank you for any other hints
Vil
---------- Původní e-mail ----------
Od: Darafei "Komяpa" Praliaskouski <me at komzpa.net>
Komu: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Datum: 20. 12. 2017 12:44:01
Předmět: Re: [postgis-users] Adaptive k-nearest neigbourh in PostGIS
it seems to me that cumulative distance is guaranteed to always be more or
equal to straight line distance, thus transforming your KNN query to
essentially KNN-in-box query.
You can add `where ST_DWithin(geom, 'SRID=32633;POINT(404419.4 5599450.3)'::
geometry, distcum)` to your select clause, and you'll get a box-based index
scan for your non-index-using query. Depending on your data distribution it
might give enough performance already.
ср, 20 дек. 2017 г. в 14:30, Vilem Ded <Ded.V at seznam.cz
(mailto:Ded.V at seznam.cz)>:
I have big table of spatial points in 2D (or 3D) (PostGIS) and distance
defined between them (let say just real spatial distance). When I create
GIST index on these points, I can efficiently get k-nearest neighbors for
each point using `<->` operator in ORDER BY statement with constant k (e.g.
20) specified in `LIMIT` statement([Postgis-official][1]).
    SELECT id, st_distance(geom,'SRID=32633;POINT(404419.4 5599450.3)'::
geometry ) as dist, geom
    FROM positions
    ORDER BY geom <-> 'SRID=32633;POINT(404419.4 5599450.3)'::geometry limit
20;
Explain analyze for that:
QUERY PLAN
     Limit  (cost=0.28..2.64 rows=10 width=36) (actual time=0.243..0.313
rows=10 loops=1)
       ->  Index Scan using positons2_gix on positions2 (cost=0.28..12059.82
rows=51146 width=36) (actual time=0.243..0.310 rows=10 loops=1)
             Order By: (up_geom <-> '0101000020797F00009A9999990DAF
184133333393365C5541'::geometry)
     Planning time: 0.109 ms
     Execution time: 0.368 ms
The thing is, that I would like to get different (dynamic) number k of
neighbors for each point such that cumulative sum ([How to compute
cumulative sum][2]) of distances to these points is less than parameter a
(let say 500m) of course maximizing k. So called adaptive k-nearest neighbor
algorithm. I could compute distance to all positions and filter it by WHERE
clause:
    select * from
    (select  *, sum(dist) over(order by dist) distcum from
         (select id, st_distance(geom,'SRID=32633;POINT(404419.4
5599450.3)'::geometry ) as dist,  geom from
        positions  ORDER BY geom <-> 'SRID=32633;POINT(404419.4
5599450.3)'::geometry) a
    ) b where distcum < 500;
explain analyze for that:
    QUERY PLAN
     Subquery Scan on b  (cost=14073.70..15608.08 rows=17049 width=52)
(actual time=155.427..186.656 rows=26 loops=1)
       Filter: (b.distcum < '500'::double precision)
       Rows Removed by Filter: 51120
       ->  WindowAgg  (cost=14073.70..14968.76 rows=51146 width=44) (actual
time=155.421..181.934 rows=51146 loops=1)
             ->  Sort  (cost=14073.70..14201.57 rows=51146 width=44) (actual
time=155.410..157.985 rows=51146 loops=1)
                   Sort Key: a.dist
                   Sort Method: quicksort  Memory: 5532kB
                   ->  Subquery Scan on a (cost=9434.16..10073.49 rows=51146
width=44) (actual time=130.931..145.989 rows=51146 loops=1)
                         ->  Sort  (cost=9434.16..9562.03 rows=51146 width=
36) (actual time=130.930..136.711 rows=51146 loops=1)
                               Sort Key: ((positions.geom <-> '0101000020797
F00009A9999990DAF184133333393365C5541'::geometry))
                               Sort Method: quicksort  Memory: 8729kB
                               ->  Seq Scan on positions (cost=0.00..5433.95
rows=51146 width=36) (actual time=0.023..95.801 rows=51146 loops=1)
     Planning time: 0.146 ms
     Execution time: 186.705 ms
but if I am not mistaken, this is sorting all points ( Sort Key: (
(positions.geom <->....) using GIST index, runs window function on all
points to get cumulative sum and then uses filter.
I would like to apply this adaptive knn for all points in my table with
about 2 000 000 rows. My proposed query is too slow for that.
Is there any way how to implement adaptive knn in PotgreSQL/PostGIS so the
computation is faster than my solution? (probably by avoiding sorting of all
points for each point)
Thank you
Vil
  [1]: https://postgis.net/docs/geometry_distance_knn.html
(https://postgis.net/docs/geometry_distance_knn.html)
  [2]: https://stackoverflow.com/questions/22841206/calculating-cumulative-
sum-in-postgresql
(https://stackoverflow.com/questions/22841206/calculating-cumulative-sum-in-postgresql)
postgis-users mailing list
postgis-users at lists.osgeo.org(mailto:postgis-users at lists.osgeo.org)
https://lists.osgeo.org/mailman/listinfo/postgis-users
(https://lists.osgeo.org/mailman/listinfo/postgis-users)"
https://lists.osgeo.org/mailman/listinfo/postgis-users"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180108/8fc7d0c7/attachment.html>
