[postgis-users] Package dependency issues installing 2.4.3 (YUM)
Regina Obe lr at pcorp.us
Fri Jan 19 07:54:44 PST 2018
Greg,
Might be better to post this to Yum PG mailing list if you are getting it from yum.postgresql.org
https://www.postgresql.org/list/pgsql-pkg-yum/
Packagers sometimes listed on PostGIS developers, so I've cc'd there.
Thanks,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Greg Barker
Sent: Thursday, January 18, 2018 9:17 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Package dependency issues installing 2.4.3
On a RedHat 7.4 machine, tried to do a "yum install postgres24_96" today and got the following:
Error: Package: postgis24_96-2.4.3-1.rhel7.x86_64 (pgdg96)
           Requires: libproj.so.12()(64bit)
           Requires: proj49
           Requires: geos36 >= 3.6.2
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
I did the same earlier this week which installed 2.4.2 and it worked fine.
One thing I noticed is that the package size for 2.4.3 is much smaller than 2.4.2:
[user at box1 ~]# yum info postgis24_96
Loaded plugins: amazon-id, rhui-lb, search-disabled-repos
Available Packages
Arch        : x86_64
Version     : 2.4.3
Release     : 1.rhel7
Repo        : pgdg96/7Server/x86_64
Summary     : Geographic Information Systems Extensions to PostgreSQL
URL         : http://www.postgis.net/
License     : GPLv2+
Description : PostGIS adds support for geographic objects to the PostgreSQL object-relational
            : database. In effect, PostGIS "spatially enables" the PostgreSQL server,
            : allowing it to be used as a backend spatial database for geographic information
            : systems (GIS), much like ESRI's SDE or Oracle's Spatial extension. PostGIS
            : follows the OpenGIS "Simple Features Specification for SQL" and has been
            : certified as compliant with the "Types and Functions" profile.
Versus:
[root at box2 ~]# yum info postgis24_96
Installed Packages
Arch        : x86_64
Version     : 2.4.2
Release     : 1.rhel7
Repo        : installed
>From repo   : pgdg96
License     : GPLv2+
As a workaround I did "yum install postgis24_96-2.4.2-1.rhel7" which succeeded.
Thanks!
Greg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180119/d9059fb7/attachment.html>
