[postgis-users] [EXTERNAL] Re: ST_Resample function question.
Birkett, Scott scott.birkett at pioneer.com
Tue Jun 12 07:47:09 PDT 2018
The comment that an unset SRID forcing a transformation to happen makes sense.
You stated that the following would fail because GDALCreateGenImgProjTransformer2 would just return null, and null can’t be transformed into a raster.
So the following fails, we have seen that.
SELECT
    ST_Resample(
            ST_SetSRID(
'0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster,
                4326),
    2, 2)
But the following still returns the same error, when a height and width change is requested.
SELECT
    ST_Resample(
            ST_SetSRID(
                4326),
    4, 4)
While this works
SELECT
    ST_Resample(
    4, 4)
Should a resample that changes the height and width still create an error?
Thanks for your help so far.
From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of Regina Obe <lr at pcorp.us>
Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Date: Monday, June 11, 2018 at 4:33 PM
To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Cc: "Gruca, Justin" <justin.gruca at pioneer.com>, "Conrad, Gabe" <gabe.conrad at pioneer.com>
Subject: [EXTERNAL] Re: [postgis-users] ST_Resample function question.
That error happens when gdal GDALCreateGenImgProjTransformer2 returns a NULL transform which I'm guessing happens if that data is already at that sampling.
I know other conditions for that are if GDAL can't load the proj library or GDAL_DATA path is not set.
Your data already has a width of 2,2 so I assume that if its already at the desired sampling it may return NULL.
For example:
SELECT ST_Resample(ST_ASRaster(
               'SRID=4326;POLYGON((0 0,2 0,2 -2,0 -2,0 0))'::geometry, 2, 2),2,2);
Yields the error you describe:
ERROR: rt_raster_gdal_warp: Could not create GDAL transformation object for output dataset creation
But if my original dimensions were width / height 4/4 and I request 2/2, then this works
               'SRID=4326;POLYGON((0 0,2 0,2 -2,0 -2,0 0))'::geometry, 4, 4),2,2);
But that doesn't explain why this doesn't work:
As far as why it works when you have no SRID, the raster code uses a hard-coded geotransform matrix when it's an unknown raster so it always gets a geotransform back it can use to apply.
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Birkett, Scott
Sent: Monday, June 11, 2018 4:27 PM
To: postgis-users at lists.osgeo.org
Cc: Gruca, Justin <justin.gruca at pioneer.com>; Conrad, Gabe <gabe.conrad at pioneer.com>
Subject: [postgis-users] ST_Resample function question.
"PostgreSQL 9.5.10 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.3 20140911 (Red Hat 4.8.3-9), 64-bit POSTGIS="2.2.5 r15298" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.0.3, released 2016/07/01" LIBXML="2.9.1" LIBJSON="0 (...)"
The raster created by …
SELECT   '0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster, is a two band raster with zeros in the first band and ones in the second band.
The following Resample works.
SELECT ST_Resample('0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster, 2, 2)
The following ST_SetSRID works
SELECT ST_SetSRID('0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster::geometry ,4326);
The following Resample does not work.
SELECT ST_Resample(ST_SetSRID('0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster, 4326), 2, 2)
Error Follows
********** Error **********
SQL state: XX000
Raster in the first band follows…
SELECT ST_AsText(geom), * FROM ST_PixelAsCentroids(ST_SetSRID('0100000200000000000000F03F000000000000F0BF00000000000000000000000000000000000000000000000000000000000000000000000002000200080000000000000000000000000000000000000000080000000001000000010000000100000001000000'::raster, 4326), 1);
"POINT(0.5 -0.5)";"0101000020E6100000000000000000E03F000000000000E0BF";0;1;1
"POINT(1.5 -0.5)";"0101000020E6100000000000000000F83F000000000000E0BF";0;2;1
"POINT(0.5 -1.5)";"0101000020E6100000000000000000E03F000000000000F8BF";0;1;2
"POINT(1.5 -1.5)";"0101000020E6100000000000000000F83F000000000000F8BF";0;2;2
Is there something with the ST_Resample function that I am missing?  I don’t understand why setting the SRID to 4326 breaks ST_Resample in this instance.  ST_SetSRID for the above raster works fine, the raster is returned and the coordinates are valid for 4326.
Any help is appreciated.
This communication is for use by the intended recipient and contains information that may be Privileged, confidential or copyrighted under applicable law. If you are not the intended recipient, you are hereby formally notified that any use, copying or distribution of this e-mail,in whole or in part, is strictly prohibited. Please notify the sender by return e-mail and delete this e-mail from your system. Unless explicitly and conspicuously designated as "E-Contract Intended", this e-mail does not constitute a contract offer, a contract amendment, or an acceptance of a contract offer. This e-mail does not constitute a consent to the use of sender's contact information for direct marketing purposes or for transfers of data to third parties. Francais Deutsch Italiano Espanol Portugues Japanese Chinese Korean http://www.DuPont.com/corp/email_disclaimer.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180612/fd2131cf/attachment.html>
