[postgis-users] Status and plans regarding circular arcs support?
Andrea Aime andrea.aime at geo-solutions.it
Tue Mar 13 09:15:07 PDT 2018
Thanks Paul!
Cheers
Andrea
On Tue, Mar 13, 2018 at 2:59 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Hi Andrea,
> In terms of "native" support for arcs, I believe the answer is "area,
> length, distance, indexes and supportive output formats", full stop.
> Everything else that accepts them does linearization.
> In terms of future improvements, I know of no ongoing work,
> particularly in the realm of things like constructive geometry or full
> predicate support. Unfortunately it's always been a somewhat narrow
> niche.
> ATB,
> P
> On Mon, Mar 12, 2018 at 8:24 AM, Andrea Aime
> <andrea.aime at geo-solutions.it> wrote:
> > Hi,
> > is there any document outlining the current status of arc support in
> > PostGIS?
> > In particular, a list of functions that can those that work off the
> native
> > curves, and those that  linear-ization instead (eventually, those that do
> > not work at all against curvilinear geometries)?
> > Maybe (and I might be dreaming here :-) ) with some indication of whether
> > they will be improvements in that regard?
> > Cheers
> > Andrea
> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V
> > for more information.
> > Ing. Andrea Aime
> > @geowolf
> > Technical Lead
> > GeoSolutions S.A.S.
> > Via di Montramito 3/A
> > 55054  Massarosa (LU)
> > phone: +39 0584 962313
> > fax: +39 0584 1660272
> > mob: +39 339 8844549
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> > finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> > cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> > information in this message that has been received in error. The sender
> does
> > not give any warranty or accept liability as the content, accuracy or
> > completeness of sent messages and accepts no responsibility  for changes
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
Regards,
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180313/ab8aeee3/attachment.html>
