[postgis-users] Sample - Points into Polygons
Thijs van den Berg thijs at sitmo.com
Fri May 25 15:01:19 PDT 2018
Or associate each point with a grid cell id using scaling and rounding of
coordinates cell_id=int(x/cell_width)+rn_cols*(y/cell_width). If it were a
3x3 tic tac toe grid you'd have 0,1,2,..,8.
Then select distinct points on that grid cell id?
Op 25 mei 2018 23:42 schreef "Darafei "Komяpa" Praliaskouski" <me at komzpa.net
> Hi,
> I see two ways to address your problem.
> First step, by area, calculate expected number of points in polygon.
> Then, depending on quality/speed tradeoff,
> fast: for each polygon you make ST_GeneratePoints, and for each point take
> 1 closest point using KNN query, then apply DISTINCT to filter duplicates.
> with some eyecandy guarantees: take KMeans of all the points in polygon
> with K you calculated. In each cluster, take ST_GeometricMedian. Take point
> from each cluster closest to cluster center.
> сб, 26 мая 2018, 00:26 карыстальнік Vispo Leblanc <vispoleblanc at gmail.com>
> напісаў:
>> Hello PostGIS users,
>> I have one table with thousand of polygons and another one with million
>> of points. I would like to select all the points that are within the
>> polygons, BUT I just want a sample of the data. Let me explain.
>> Let’s say I have a polygon of 1,000 square meter with 60 points, ideally
>> I would like to take only 1 points. But if the polygon is 10,000 square
>> meter with 600 points then ideally I would take only 10 points. Also, in a
>> perfect world, I would only select a sample of points that are spread out
>> enough to be representative of the polygons. Let’s take the 10,000 square
>> meters polygon for example, I would only select 10 points that are
>> everywhere in the polygon and not 10 points that are within 10 meters of
>> each other’s.
>> I draw the following diagram to explain:
>> [image: image.png]
>> Please let me know if you have any ideas or functions I can use to solve
>> my problem.
>> Thank you :-)
>> Vispo
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180526/96a3f180/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180526/96a3f180/attachment.png>
