[postgis-users] Installing PostGIS 2.3.8 over PostGres 9.4, Windows
Regina Obe lr at pcorp.us
Tue May 29 09:52:37 PDT 2018
Mauro,
Is there a reason you want to use PostgreSQL 9.4 and not something newer?  PostgreSQL 9.4 is pretty old at this point.
If you can I would suggest using a newer version.
Note that BigSQL PostgreSQL 9.4 has its own PostGIS too.  I'm not sure which versions are offered for 9.4.  It does lack SFCGAL in it.
If you do from command shell (cd'd into bigsql folder)
pgc list
it will give a list of extension options.
Then it should be as simple as
pgc install postgis23
But if you want to use 9.4 and the 2.3.8dev binaries, then YES, you'd need to use this one
https:// <http://www.enterprisedb.com/downloads/postgres-postgresql-downloads> www.enterprisedb.com/downloads/postgres-postgresql-downloads
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Mauro Gregorio Binetti
Sent: Tuesday, May 29, 2018 12:19 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Cc: Mauro Gregorio Binetti <maurogregorio.binetti at exprivia.it>
Subject: Re: [postgis-users] Installing PostGIS 2.3.8 over PostGres 9.4, Windows
Hi Regina,
first of all thank you very much for responding so fast.
Your assumption is correct. I installed PostgreSQL 9.4.18 using BigSQL distribution.
Your explanation is very clear to me now.
I need to use version 9.4 of PostgreSQL so, I understand I have to start by changing this one. My reference must be
Correct?
Then I can repeat PostGIS installation using the same zip file:
https://winnie.postgis.net/download/windows/pg94/buildbot/postgis-pg94-binaries-2.3.8devw64gcc48.zip
Correct?
Regards,
Mauro
On Tue, May 29, 2018 at 5:02 PM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Which distribution of PostgreSQL are you using?
It looks to me like you are using a distribution incompatible with the  EDB distribution which the 9.4 binaries I built were built for.
For example if you are using BigSQL, only PostgreSQL 9.5 and above binaries on Winnie will work with that.
The reason for this is
Prior to PostgreSQL 9.5, EnterpriseDb used to compile their windows versions with FLOAT8PASSBYVAL =  false
So to accommodate that, I built < 9.5 with FLOAT8PASSBYVAL = false
However BigSQL windows distributions have always been built with FLOAT8PASSBYVAL = true
So the 9.4 builds I built for EDB WILL NOT WORK with 9.4 BigSQL
In Version PostgreSQL 9.5+, EDB changed their windows builds to build with FLOAT8PASSBYVAL =true as well
So from that point forward, the builds are compatible.
 <http://postgis.net/windows_downloads/> http://postgis.net/windows_downloads/
(that's why I put a note on that page that for BigSQL 9.5+, you can use the binaries here if you want extra stuff.  I probably maybe should have explained that better (and put a big DO NOT USE if using < 9.5 on BigSQL)
Thanks,
Regina
From: postgis-users [mailto: <mailto:postgis-users-bounces at lists.osgeo.org> postgis-users-bounces at lists.osgeo.org] On Behalf Of Mauro Gregorio Binetti
Sent: Tuesday, May 29, 2018 10:29 AM
To:  <mailto:postgis-users at lists.osgeo.org> postgis-users at lists.osgeo.org
Cc: Mauro Gregorio Binetti < <mailto:maurogregorio.binetti at exprivia.it> maurogregorio.binetti at exprivia.it>
Subject: [postgis-users] Installing PostGIS 2.3.8 over PostGres 9.4, Windows
Hi guys,
I have downloaded the subsequent zipfile:
 <https://winnie.postgis.net/download/windows/pg94/buildbot/> https://winnie.postgis.net/download/windows/pg94/buildbot/ postgis-pg94-binaries-2.3.8devw64gcc48.zip
FOr the subsequent command:
"%PGBIN%\psql"  -d "%THEDB%" -c "CREATE EXTENSION postgis;"
shown in bat file: makepostgisdb_using_extensions.bat
I have the subsequent error:
ERROR:  incompatible library "C:/__APPL/pg94/../pg94/lib/postgresql/postgis-2.3.dll": magic block mismatch
DETTAGLI: Server has FLOAT8PASSBYVAL = true, library has false.
I have modified boolean flag value to false in subsequent files:
*        pg94\include\postgresql\server\pg_config.h
*        pg94\include\pg_config.h
but I continue to have same error.
Can you please give me some advice.
Thank you in advance.
Mauro
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20180529/5d560b3d/attachment.html>
