[postgis-users] PostgreSQL 12 and PostGIS
Bo Guo bo.guo at gisticinc.com
Mon Dec 23 07:53:54 PST 2019
Regina,  Since the new cluster was never created so I just upgraded the
extension by running your select statement which returned:
POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1
27a5e771" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3,
released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99"
LIBPROTOBUF="1.2.1" TOPOLOGY RASTER
Not sure if the postgis gets updated though, as my problem persisted
with the same error message.
Cheers,
Bo
On 12/22/19 11:03 PM, Regina Obe wrote:
> Okay this one is caused by a change in PostgreSQL 12 catalogs.
> Fixed in PostGIS 2.5.2 I believe -
> https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.5.2/NEWS (the
> pg_constraint change)
> So to upgrade, what you need to do is
> 1)Reinit your new cluster (as I think at this point your new cluster
> is in an unstable state)
> 2) Restart up your old cluster and run the upgrade on it -  SELECT
> postgis_extensions_upgrade();  - that will bring it up to 2.5.2 and
> fix the views so they are compatible with 12.
> 3)Then do your migration again
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Bo Guo
> *Sent:* Monday, December 23, 2019 12:47 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] PostgreSQL 12 and PostGIS
> Hi, Regina,
> After sucessful upgrade to the Dev server, I started upgrading the
> Test server which had the following version profile;
> select version();
> PostgreSQL 11.3 (Ubuntu 11.3-1.pgdg16.04+1) on x86_64-pc-linux-gnu,
> compiled by gcc (Ubuntu 5.4.0-6ubuntu1~16.04.11) 5.4.0 20160609, 64-bit
> and
> select postgis_full_version();
> POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="100" (procs need upgrade for
> use with "110") GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 4.9.2, 08
> September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3"
> LIBJSON="0.11.99" LIBPROTOBUF="1.2.1" (core procs from "2.5.1 r17027"
> need upgrade) TOPOLOGY (topology procs from "2.5.1 r17027" need
> upgrade) RASTER (raster procs from "2.5.1 r17027" need upgrade)
> However the pg_upgradecluster command failed for different reason as
> shown in the last few lines in the log file.  I thought Dev and Test
> servers had been identical in terms of OS and Postgres/PostGIS
> install.  Look like there was some difference...
> pg_restore: creating VIEW "postgis.geography_columns"
> pg_restore: creating VIEW "postgis.geometry_columns"
> pg_restore: while PROCESSING TOC:
> pg_restore: from TOC entry 496; 1259 54951 VIEW geometry_columns postgres
> pg_restore: error: could not execute query: ERROR:  column s.consrc
> does not exist
> LINE 28:             "replace"("split_part"("s"."consrc", ''''::"text...
> HINT:  Perhaps you meant to reference the column "s.conkey" or the
> column "s.conbin".
> Command was:
> -- For binary upgrade, must preserve pg_type oid
> SELECT
> pg_catalog.binary_upgrade_set_next_pg_type_oid('54953'::pg_catalog.oid);
> -- For binary upgrade, must preserve pg_type array oid
> SELECT
> pg_catalog.binary_upgrade_set_next_array_pg_type_oid('54952'::pg_catalog.oid);
> -- For binary upgrade, must preserve pg_class oids
> SELECT
> pg_catalog.binary_upgrade_set_next_heap_pg_class_oid('54951'::pg_catalog.oid);
> CREATE VIEW "postgis"."geometry_columns" AS
> SELECT ("current_database"())::character varying(256) AS
> "f_table_catalog",
>     "n"."nspname" AS "f_table_schema",
>     "c"."relname" AS "f_table_name",
>     "a"."attname" AS "f_geometry_column",
>     COALESCE("postgis"."postgis_typmod_dims"("a"."atttypmod"),
> "sn"."ndims", 2) AS "coord_dimension",
>     COALESCE(NULLIF("postgis"."postgis_typmod_srid"("a"."atttypmod"),
> 0), "sr"."srid", 0) AS "srid",
> ("replace"("replace"(COALESCE(NULLIF("upper"("postgis"."postgis_typmod_type"("a"."atttypmod")),
> 'GEOMETRY'::"text"), "st"."$
>    FROM (((((("pg_class" "c"
>      JOIN "pg_attribute" "a" ON ((("a"."attrelid" = "c"."oid") AND
> (NOT "a"."attisdropped"))))
>      JOIN "pg_namespace" "n" ON (("c"."relnamespace" = "n"."oid")))
>      JOIN "pg_type" "t" ON (("a"."atttypid" = "t"."oid")))
>      LEFT JOIN ( SELECT "s"."connamespace",
>             "s"."conrelid",
>             "s"."conkey",
>             "replace"("split_part"("s"."consrc", ''''::"text", 2),
> ')'::"text", ''::"text") AS "type"
>            FROM "pg_constraint" "s"
>           WHERE ("s"."consrc" ~~* '%geometrytype(% = %'::"text")) "st"
> ON ((("st"."connamespace" = "n"."oid") AND ("st"."conrel$
>             "s"."conrelid",
>             "s"."conkey",
>             ("replace"("split_part"("s"."consrc", ' = '::"text", 2),
> ')'::"text", ''::"text"))::integer AS "ndims"
>           WHERE ("s"."consrc" ~~* '%ndims(% = %'::"text")) "sn" ON
> ((("sn"."connamespace" = "n"."oid") AND ("sn"."conrelid" = "$
>             "s"."conrelid",
>             "s"."conkey",
>             ("replace"("replace"("split_part"("s"."consrc", ' =
> '::"text", 2), ')'::"text", ''::"text"), '('::"text", ''::"text$
>           WHERE ("s"."consrc" ~~* '%srid(% = %'::"text")) "sr" ON
> ((("sr"."connamespace" = "n"."oid") AND ("sr"."conrelid" = "c$
>   WHERE (("c"."relkind" = ANY (ARRAY['r'::"char", 'v'::"char",
> 'm'::"char", 'f'::"char", 'p'::"char"])) AND (NOT ("c"."relname"$
> -- For binary upgrade, handle extension membership the hard way
> ALTER EXTENSION "postgis" ADD VIEW "postgis"."geometry_columns";
> On 12/22/19 9:11 PM, Bo Guo wrote:
>     Yeh!  Thanks you, Regina!
>     On 12/22/19 8:54 PM, Regina Obe wrote:
>         Okay I ran into that issue too.
>         It happens if you have PostGIS not installed in public.
>         I have the issue ticketed here – I thought I had fixed this
>         already in 3.0.1 (not yet released yet), but evidentally I
>         haven’t or forgot to close this ticket.
>         https://trac.osgeo.org/postgis/ticket/4555
>         The workaround is to do this:
>         CREATE EXTENSION postgis_raster FROM unpackaged VERSION
>         "3.0.0" SCHEMA <schema where you installed postgis>;
>         [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of
>         *Bo Guo
>         *Sent:* Sunday, December 22, 2019 10:36 PM
>         <mailto:postgis-users at lists.osgeo.org>
>         Thanks, Regina!  I am running PostgeSQL 12 now!
>         However, when I ran *SELECT*PostGIS_Extensions_Upgrade(); the
>         second time, I have the following msg.
>         NOTICE: Extension postgis_sfcgal is not available or not
>         packagable for some reason
>         NOTICE: Packaging extension postgis_raster
>         WARNING: 'postgis.gdal_datapath' is already set and cannot be
>         changed until you reconnect
>         WARNING: 'postgis.gdal_enabled_drivers' is already set and
>         cannot be changed until you reconnect
>         WARNING: 'postgis.enable_outdb_rasters' is already set and
>         ERROR: function public.st_srid(geometry) does not exist
>         LINE 1: ..._makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0,
>         public.ST_... ^
>         HINT: No function matches the given name and argument types.
>         You might need to add explicit type casts.
>         QUERY: SELECT public.ST_makeemptyraster($1, $2, $3, $4, $5,
>         -($5), 0, 0, public.ST_SRID('POINT(0 0)'::geometry))
>         CONTEXT: SQL statement "CREATE EXTENSION postgis_raster FROM
>         unpackaged"
>         PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
>         SQL state: 42883
>         On 12/22/19 8:09 PM, Regina Obe wrote:
>             NO NO  don’t do that.  Those set of libraries aren’t
>             compatible with each other.
>             The PostGIS 3.0 and 2.5 from 12 are compatible with each
>             other however.
>             So
>             What you want to do is
>             cp /usr/lib/postgresql/12/lib/postgis-3.so
>             /usr/lib/postgresql/12/lib/postgis-2.5.so
>             cp /usr/lib/postgresql/12/lib/postgis_raster-3.so
>             /usr/lib/postgresql/12/lib/rtpostgis-2.5.so
>             cp /usr/lib/postgresql/12/lib/postgis_topology-3.so
>             /usr/lib/postgresql/12/lib/postgis_topology-2.5.so
>             Then after the upgrade in each of your databases run:
>             And then run it again to rebundle the raster into it’s own
>             extension
>             Then if you don’t need raster, you can
>             DROP EXTENSION postgis_raster;
>             Once you are done upgrading your databases, you can delete
>             thr *-2.5.so files you created in the 12 cluster.
>             Of *Bo Guo
>             *Sent:* Sunday, December 22, 2019 10:01 PM
>             Thanks, Regina,
>             I copied the three 2.5 lib files
>             from/usr/lib/postgresql/11/lib to /usr/lib/postgresql/12/lib:
>             guob at yuma:/usr/lib/postgresql/12/lib$ ls -al *post*
>             -rw-r--r-- 1 root root  456832 Dec 22 19:49 postgis-2.5.so
>             -rw-r--r-- 1 root root 1351536 Oct 28 21:24 postgis-3.so
>             -rw-r--r-- 1 root root  847424 Oct 28 21:24
>             postgis_raster-3.so
>             -rw-r--r-- 1 root root  364224 Dec 22 19:49
>             -rw-r--r-- 1 root root  569152 Oct 28 21:24
>             -rw-r--r-- 1 root root  100264 Nov 12 03:33 postgres_fdw.so
>             -rw-r--r-- 1 root root  399136 Dec 22 19:50 rtpostgis-2.5.so
>             However, the three lib files are still in the
>             loadable_libraries.txt file.
>             Bo
>             On 12/22/19 7:42 PM, Regina Obe wrote:
>                 Bo,
>                 Do you have the postgis-2.5.so, rtpostgis-2.5.so, postgis_topology-2.5.so
>                 files in
>                 And
>                 Those are the files it's complaining about.
>                 From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
>                 Of Bo Guo
>                 Sent: Sunday, December 22, 2019 9:16 PM
>                 To:postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>                 Subject: Re: [postgis-users] PostgreSQL 12 and PostGIS
>                 Regina and Stefan,
>                 I might have run into a similar issues today as I was  trying to upgrade
>                 PostgreSQL 11 w/ PostGIS 2.5 to PostgreSQL 12 w/ PostGIS 3.0.
>                 The pg_upgradecluster command (sudo pg_upgradecluster -m upgrade 11 main)
>                 failed its check for the following required libraries:
>                      could not load library "$libdir/postgis-2.5": ERROR:  could not access
>                 file "$libdir/postgis-2.5": No such file or directory
>                      could not load library "$libdir/rtpostgis-2.5": ERROR:  could not access
>                 file "$libdir/rtpostgis-2.5": No such file or directory
>                      could not load library "$libdir/postgis_topology-2.5": ERROR:  could not
>                 access file "$libdir/postgis_topology-2.5": No such file or directory
>                 I have postgis-2.5 in the /usr/share/postgresql/11/contrib/ folder AND
>                 /usr/share/postgresql/12/contrib/ folder.  I also have postgis-3.0 under
>                 /usr/share/postgresql/12/contrib/.
>                 Thanks for your help!
>                 Bo
>                 Gistic Research, Inc.
>                 On 10/4/19 8:16 AM, Regina Obe wrote:
>                 Stefan,
>                 Which distro do you get your PostgreSQL 12 from.  I’m assuming
>                 apt.postgresql.org
>                 If so you should report on their mailing list, as that would be a packaging
>                 bug,not a PostGIS one and no one on the PostGIS project is on the apt team.
>                 https://www.postgresql.org/list/pgsql-pkg-debian/
>                 Thanks,
>                 Regina
>                 Of Stefan Wolf
>                 Sent: Friday, October 4, 2019 6:19 AM
>                 Subject: [postgis-users] PostgreSQL 12 and PostGIS
>                 Today I’ve installed the brand new PostgreSQL 12  on Ubuntu 18.04
>                 “apt-get install postgis”  will install PostGIS 2.5.2, but the  PATH is
>                 wrong:  /usr/share/postgresql/11/…
>                 So CREATE EXTENSION postgis will fail.
>                 Greetings from Berlin
>                 -Stefan Wolf-
>                 _______________________________________________
>                 postgis-users mailing list
>                 https://lists.osgeo.org/mailman/listinfo/postgis-users
>             Regards,
>             Bo Guo, PhD, PE
>             President
>             2033 E Warner Rd Ste 105
>             Tempe, AZ 85284
>             www.gisticinc.com  <http://www.gisticinc.com>
>             www.youtube.com/linearbench  <http://www.youtube.com/linearbench>
>             Office: 480-656-9962
>             Cell: 602-570-4697
>         Regards,
>         Bo Guo, PhD, PE
>         President
>         Tempe, AZ 85284
>         Cell: 602-570-4697
>     Regards,
>     Bo Guo, PhD, PE
>     President
>     Tempe, AZ 85284
>     Cell: 602-570-4697
> Regards,
> Bo Guo, PhD, PE
> President
> Tempe, AZ 85284
> Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191223/df32e1e9/attachment.html>
