[postgis-users] PostGIS Topology with Z coordinate
Berchet, Adrien adrien.berchet at forcity.com
Thu Jan 10 01:44:01 PST 2019
Thank you for your answer, I reply in the text body.
Le mer. 9 janv. 2019 à 17:44, Sandro Santilli <strk at kbt.io> a écrit :
> On Tue, Jan 08, 2019 at 01:00:54PM +0100, Berchet, Adrien wrote:
> > Hello,
> > I am testing PostGIS Topology with 3D geometries and I am not sure of the
> > expected behaviour in this case. In the tests I conducted, it seems that
> > PostGIS Topo just ignores the Z components when searching for
> intersection
> > between geometries and thus creates some nodes where it is not needed. Is
> > it the normal behaviour please? Is it possible to build a real 3D
> topology
> > with PostGIS Topo?
> Real 3D is not currently supported by PostGIS Topology.
Ok, I missunderstood that point.
So is it possible to manage a kind of multilayer topology, to manage
bridges and tunnels in a network for exemple?
> I don't understand your statement about creating unneeded nodes
> though, do you mean multiple nodes with same x,y but different z
> are created ? Check out topology/test/regress/topo2.5d.sql if
> you want to add your case there and provide a complete scenario.
No, I meant that nodes are created even if the 'intersecting' lines have
different Z coordinates. It surprised me but you previously stated that it
is the expected behaviour. Thus the Z coordinate of a topology is only
intended to represent the relief of the topology, right?
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Les informations contenues dans ce message et ses pièces jointes sont
confidentielles et adressées à l'intention exclusive des personnes ou
entités destinataires. Toute utilisation, diffusion, publication ou copie
sans autorisation explicite est strictement interdite. Si vous avez reçu ce
message par erreur, merci de le signaler à son expéditeur et de le détruire
immédiatement, ainsi que toutes les pièces jointes, sans en conserver de
copie. ForCity décline toute responsabilité si ce message a été altéré,
déformé ou falsifié.
The information contained in this communication and
any attachments are confidential and intended solely for the use of the
individual or entity to whom it is addressed. Any use, dissemination, or
copy without express authorization is strictly prohibited. If you have
received this email in error, please notify the sender and delete the
original message immediately, including its attachments, without saving a
copy. ForCity is not liable for messages that have been modified, changed
or falsified.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190110/ab5841eb/attachment.html>
