[postgis-users] Geography/geometry
Birgit Laggner birgit.laggner at thuenen.de
Mon Jan 21 04:17:39 PST 2019
Hi Simon,
I assume, you are trying to get this all done in one query, right? Did you try to throw ST_MakeValid into the mix? Like: ST_Transform(ST_Union(ST_MakeValid(ST_Transform(a.geog4326::geometry, 3857))), 4326)::geography
Regards,
Birgit
Von: "Simon Greener" <simon at spatialdbadvisor.com>
An: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Gesendet: Montag, 21. Januar 2019 06:23:10
Betreff: [postgis-users] Geography/geometry
Folks,
I'm in a situation where I need to ST_Union or ST_Collect some osm_county Polygon (not MultiPolygon) data for Ireland.
Now, because ST_Union or ST_Collect do not support geography, I cast to geometry before calling.
select min(a.osm_id) as osm_id,
a.name,
count(*) as parts,
ST_Union(a.geog4326::geometry)::geography as geog4326 -- or ST_Collect
from data.osm_county as a
group by a.name;
Whence I get this:
ERROR: lwgeom_area_spher(oid) returned area < 0.0
Investigating I get results like this:
select distinct st_isvalidreason(a.geog4326::geometry) from data.osm_county as a;
"Hole lies outside shell[-10.2589459 53.9746452]"
etc
I guess this is expected because geodetic lines in the source geography are being treated as straight in the cast'd geometry.
If I use ST_Transform to project a 4326 poly to a 3857 and then call the ST_Union aggregate, or identify a single geography that has the invalidity and execute a self-union, I get the following in both situations.
ERROR: GEOSUnaryUnion: TopologyException: Input geom 0 is invalid: Hole lies outside shell at or near point -1148162.9982628345 7095296.1166736316 at -1148162.9982628345 7095296.1166736316
I can't for the life of me work out how to complete the aggregated ST_Union on the 4326 geography data.
Anyone point out what I am doing wrong or give me a pointer to what I can do to achieve the aggregated union?
Regards
Simon
Spatial Advice & Solutions Architecture
Database Spatial Stored Procedure Designer
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE FME
Awarded "2011 Oracle Spatial Excellence Award for Education and Research"
A: 39 Cliff View Drive, Allens Rivulet, 7150, Tas, Aust
W: www.spdba.com.au
E: simon at spdba.com.au
V: +61 362 396 397
M: +61 418 396 391
GITC Supplier: T1005
Skype: sggreener
Long: 147.20515 (147° 12' 18" E)
Lat: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190121/041a92ec/attachment.html>
