[postgis-users] PARTIALLY RESOLVED: Geography/geometry
Simon (SPDBA) Greener simon at spatialdbadvisor.com
Mon Jan 21 20:29:24 PST 2019
I'll do some more checks to see if ogr2ogr really is the problem.
Simon
⁣Sent from BlueMail ​
On 22 Jan. 2019, 15:22, at 15:22, Martin Davis <mtnclimb at gmail.com> wrote:
>Perhaps log this as an OGR issue [1]?  Probably need to bisect the
>problem
>a bit more though (e.g. reduce the input to a single failing polygon).
>[1] https://github.com/OSGeo/gdal/issues
>On Mon, Jan 21, 2019 at 7:06 PM Simon Greener
><simon at spatialdbadvisor.com>
>wrote:
>> I replaced the shapefile load script dropping ogr2ogr in favor of
>> shp2pgshp.
>> This appears to have given me clean multipolygons as nothing was
>reported
>> by the following:
>> select ST_ISValidReason(a.geog4326::geometry)
>>   from data.osm_county as a
>>  where ST_IsValidReason(a.geog4326::geometry) <> 'Valid Geometry'
>> I discovered though this process that the original shapefile had 10
>> counties that were duplicated.
>> I used postgresql to delete the duplicates.
>> All my SQL appears to be working.
>> Perhaps Martin is right: there is something wrong with the ogr2ogr
>load
>> (though I switched from -nlt POLYGON to -nlt PROMOTE_TO_MULTI and it
>didn't
>> make any difference).
>> I think this request for help can now be closed.
>> Thanks to all.
>> regards
>> Simon
>> Just ’select geom’ will return the extended hexwkb (which we should
>have
>> JTS support as a matter of convenience). If you need pure standard
>hex wkb,
>> then
>> select encode(st_asbinary(geom), ‘hex’)
>> will do that
>> P
>> On Jan 21, 2019, at 2:39 PM, Martin Davis <mtnclimb at gmail.com> wrote:
>> Not much help, I'm afraid.   I need the geometry in WKBHex.  Not sure
>> offhand how to get that out of PostGIS.
>> Just post the WKT and let's see what that looks like.
>> On Mon, Jan 21, 2019 at 1:52 PM Simon Greener
>> wrote:
>>> Try here for an example:
>>> https://www.dropbox.com/s/n234bc6i5hj7y4o/Ireland.sql?dl=0
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> Regards
>> Simon
>> *Spatial Advice & Solutions ArchitectureDatabase Spatial Stored
>Procedure
>> Designer*
>> Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE FME
>> Awarded "2011 Oracle Spatial Excellence Award for Education and
>Research"
>> A: 39 Cliff View Drive, Allens Rivulet, 7150, Tas, Aust
>> W: www.spdba.com.au
>> E: simon at spdba.com.au
>> V: +61 *362 396 397*
>> M: +61 *418 396 391*
>> GITC Supplier: T1005
>> Skype: sggreener
>> Long: 147.20515 (147° 12' 18" E)
>> Lat: -43.01530 (43° 00' 55" S)
>> GeoHash: r22em9r98wg
>> NAC:W80CK 7SWP3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190122/9d2d39d1/attachment.html>
