[postgis-users] raster regions
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Jul 15 10:43:22 PDT 2019
That could translate into something like this in PostGIS:
WITH floodareas AS (
  SELECT ST_MapAlgebra(rast, ‘1BB’, ‘CASE WHEN [rast] < 10 THEN 1 ELSE NULL END’) rast
  FROM elevation
SELECT d.*
FROM districts d, floodareas f
WHERE ST_Intersects(g.geom, f.rast)
NULL becomes nodata values. You could also use ST_Reclass() instead of ST_Mapalgebra().
Pierre
De : postgis-users <postgis-users-bounces at lists.osgeo.org> De la part de Joao Cordeiro
Envoyé : 15 juillet 2019 10:19
À : 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Objet : [postgis-users] raster regions
Hi there,
I am not actually a POSTGIS user, or developer, although I am doing some research of integration of vector -raster in a dbms context. My main question s about identifying regions represented in a domain like the "hybrid raster" so that they can be referred to in a query. For example, I would like to write something like "select d from districts where d.geometry touches flooding", where "flooding" indicates an expression intended to decide on the pertinence of locations to a flooding ​​risk area described, for instance through map algebra.
Thanks for any hints or suggestions.
Att.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190715/37341b1a/attachment.html>
