[postgis-users] ST_Intersection does not preserve M value
Bo Guo bo.guo at gisticinc.com
Tue May 7 07:17:19 PDT 2019
FME, which sources from GEOS
(https://cdn.safe.com/resources/fme/FMEDesktop_Legal_Notices_2019.0.pdf),
did not handle the measurement with its Clipper transformer until about
two years ago.  Wonder if they achieved this through direct update the
GEOS lib or through post-GEOS enhancement.
On 5/6/19 2:53 PM, Martin Davis wrote:
> Not exactly the same thing - I believe that ticket is referring to
> just the WKB format handling?
> I can make a ticket for measure handling by the overlay operations if
> there isn't one already.
> On Mon, May 6, 2019 at 11:31 AM Darafei "Komяpa" Praliaskouski
> <me at komzpa.net <mailto:me at komzpa.net>> wrote:
>     It's in backlog for 6 years already I believe:
>     https://trac.osgeo.org/geos/ticket/466
>     пн, 6 мая 2019, 19:33 карыстальнік Martin Davis
>     <mtnclimb at gmail.com <mailto:mtnclimb at gmail.com>> напісаў:
>         It should be possible to post-process GEOS results to
>         re-populate the M values if present.  Linear interpolation
>         could be used to estimate values at intra-segment points.  We
>         can put this on the list for future development.
>         On Mon, May 6, 2019 at 4:48 AM Darafei "Komяpa" Praliaskouski
>             Hi,
>             GEOS operations do not preserve M, but sometimes preserve
>             Z. You can try
>             ST_SwapOrdinates(ST_Intersection(ST_SwapOrdinates(geom,
>             'zm'),...), 'zm').
>             On Thu, May 2, 2019 at 5:19 AM Bo Guo
>             <bo.guo at gisticinc.com <mailto:bo.guo at gisticinc.com>> wrote:
>                 Hi there,
>                 I was trying to cut a portion of the LRS route with an
>                 area using
>                 ST_Intersection.  However the resulting route no
>                 longer carries measure
>                 value.  The behavior is the same for version 9.6 or
>                 the latest version
>                 11.  Anyone has any suggestions?
>                 Thanks!
>                 Bo
>                 _______________________________________________
>                 postgis-users mailing list
>                 postgis-users at lists.osgeo.org
>                 <mailto:postgis-users at lists.osgeo.org>
>                 https://lists.osgeo.org/mailman/listinfo/postgis-users
>             Darafei Praliaskouski
>             Support me: http://patreon.com/komzpa
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Bo Guo, PhD, PE
Gistic Research, Inc.
2033 E Warner Rd. Ste 105
Tempe, AZ 85284
www.gisticinc.com
Tel: 480-656-9962
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190507/044f747e/attachment.html>
