[postgis-users] Any way of assigning a name alias to the system "postgres" database?
Jorge Gustavo Rocha jgr at di.uminho.pt
Wed May 22 08:11:27 PDT 2019
Hi Bob,
The goal is to use pg_services on the client side, ie, to configure the
ESRI client. Does ESRI clients work with pg_services? (I don't know!).
It's implemented in the Postgresql library, so clients rely on the
library to do the connection.
I used pgBouncer for several years and it worked quite well. It is stable.
Good luck,
Jorge
Às 16:00 de 22/05/19, Basques, Bob (CI-StPaul) escreveu:
> Hi Jorge,
> I found the info on the pg_service.conf file, and it works as described
> for a local connection.  I need to connect from a remote location.  Also
> looked at pgBouncer, but not sure how stable that is.
> Trying to connect ESRI client to Postgres on the “postgres” database,
> which ESRI outlaws for some odd reason saying it’s a system table.  We
> have been using the “postgres” DB for quite a long time, and across many
> of our automated systems which are connected to it that would need to be
> changed to use a different name.
> bobb
>> On May 21, 2019, at 5:36 PM, Jorge Gustavo Rocha <jgr at di.uminho.pt
>> <mailto:jgr at di.uminho.pt>> wrote:
>> Think Before You Click: This email originated outside our organization.
>> Hi Bob,
>> In which context you want to use an alias?
>> If it is just for connecting to the database, check pg_services.conf
>> [1]. It allows you to use a name that will be resolved by the local
>> pg_service.conf file.
>> You can also use a client pool manager, like pgBouncer. It allows you to
>> use a local name, different from the database name.
>> I hope it helps.
>> Regards,
>> Jorge Gustavo
>> [1] https://www.postgresql.org/docs/11/libpq-pgservice.html
>> [2] https://pgbouncer.github.io/
>> Às 20:19 de 21/05/19, Basques, Bob (CI-StPaul) escreveu:
>>> All (trying PostGIS users first),
>>> I have a need to call it by another name, but also to leave it named as
>>> is for legacy stuff.
>>> Anyone know of a way to do this?
>>> Thanks
>>> bobb
>>> Those who believe in telekinetics, raise my hand.
>>> —Kurt Vonnegut
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Tel: +351 253604480 <tel:+351%20253604480>
>> Fax: +351 253604471 <tel:+351%20253604471>
>> Móvel: +351 910333888 <tel:+351%20910333888>
>> skype: nabocudnosor
> "Glory is fleeting, but obscurity is forever."
>     - Napoleon Bonaparte
J. Gustavo
Jorge Gustavo Rocha
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
skype: nabocudnosor
