[postgis-users] postgis-3.1.0beta2 released
Paul Ramsey pramsey at cleverelephant.ca
Fri Dec 11 10:09:31 PST 2020
Since there were a few quick additions to beta1, I have dropped a beta2. The next release will be rc1 and then final, barring any emergency.
 * Enhancements *
  - #4814, Do not drop empty geometry components when converting
           to GEOS (Sandro Santilli)
  - #4815, Fix GEOS conversion of POINT EMPTY to retain type
           (Sandro Santilli)
  - #4813, ST_MakeValid removing NaN coordinates (Sandro Santilli)
> On Dec 9, 2020, at 4:25 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> This is a beta1 release, for testing and quality assurance, to be followed shortly by a final release. If you're interested in the stability and usability of PostGIS, please take a little time to ensure that you can build and use this release.
> https://download.osgeo.org/postgis/source/postgis-3.1.0beta1.tar.gz
> https://postgis.net/2020/12/09/postgis-3.1.0beta1/
> There have been a few changes since the alpha3 release.
> * Breaking changes *
>  - #4214, Deprecated ST_Count(tablename,...), ST_ApproxCount(tablename, ...)
>           ST_SummaryStats(tablename, ..),
>           ST_Histogram(tablename, ...), ST_ApproxHistogram(tablename, ...),
>           ST_Quantile(tablename, ...), ST_ApproxQuantile(tablename, ...) removed.
>           (Darafei Praliaskouski)
> * Enhancements *
>  - #4801, ST_ClusterKMeans supports weights in POINT[Z]M geometries (Darafei Praliaskouski)
>  - #4804, ST_ReducePrecision (GEOS 3.9+) allows valid precision reduction (Paul Ramsey)
>  - #4805, _ST_SortableHash exposed to work around parallel soring performance issue
>           in Postgres. If your table is huge, use ORDER BY _ST_SortableHash(geom)
>           instead of ORDER BY geom to make parallel sort faster (Darafei Praliaskouski)
>  - #4625, Correlation statistics now calculated.
>           Run ANALYZE for BRIN indexes to start kicking in.
>  - Fix axis order issue with urn:ogc:def:crs:EPSG in ST_GeomFromGML()
>           (Even Roualt)
