[postgis-users] Errors in loading table with geom which was produced with pg-dump
rmrodriguez at carto.com rmrodriguez at carto.com
Thu Jan 23 08:52:07 PST 2020
On Thu, Jan 23, 2020 at 5:43 PM Shaozhong SHI <shishaozhong at gmail.com> wrote:
> Numerous errors were found when loading tables with psql.exe.  These tables were produced with pg_dump.exe.
What are those errors and what commands did you run to dump and to
restore the data?
Also, does the target database has the same Postgis extensions
installed? Which versions?
Raúl Marín Rodríguez
carto.com
