[postgis-users] Errors in loading table with geom which was produced with pg-dump
rmrodriguez at carto.com rmrodriguez at carto.com
Thu Jan 23 09:28:33 PST 2020
On Thu, Jan 23, 2020 at 6:23 PM Shaozhong SHI <shishaozhong at gmail.com> wrote:
> I used pg_dump to dump a table with from.  Then, I used psql to load it to another database, but it showed numerous errors.
> Why does that happen?
You are not providing any information to debug the issue. The
following information would help:
- Postgresql and Postgis version of both the source and target database.
- The command used to dump the data.
- The command used to import the data.
- The error messages.
Raúl Marín Rodríguez
carto.com
