[postgis-users] ST_AREA(geom) returns incorrect area
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Fri Jun 12 17:33:45 PDT 2020
ST_Area and ST_length are computed in units of the object. for WGS84
that is degrees. If you want meters then cast the gem to a geography:
st_area(geom::geography)
st_length(geom::geography)
and for length you have other function that compute it in terms of spheriod.
-Steve
On 6/12/2020 7:30 PM, Clifford Snow wrote:
> When I run st_area(geom) against a geom in WGS84, my understanding is
> that postgis returns the area in square meters. It's not. Instead it
> returns something much smaller. The areas I'm interested in are small
> bounding boxes so spherical measurements should be all that different.
> I verified that the table SRID is 4326. The boxes all display
> correctly in both Pgadmin4 and QGIS.
> For example, a bbox around a house returns 9.84003999925341e-09. Yet
> QGIS calculates it as 113.73 sqm. The QGIS calculation seems to be
> more accurate.
> I know I'm doing something very wrong. Any help would be appreciated.
> Best,
> Clifford
> @osm_washington
> www.snowandsnow.us <https://www.snowandsnow.us>
> OpenStreetMap: Maps with a human touch
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
