[postgis-users] Fwd: Problem with "undefined symbol: GEOSMakeValid_r"
Marco Boeringa marco at boeringa.demon.nl
Mon May 11 03:57:21 PDT 2020
Hi all,
Anyone an idea what is wrong?
I am still running into the issues described below trying to upgrade my
PostGIS install from 2.5.4 to 3.0.1, and am starting to get convinced
something in the PostGIS installers for Ubuntu 20.04 Focal is busted.
Why would the PostGIS 3.0.1 installation fail on the inability to
overwrite the "shp2pgsql-gui.desktop" file? And if that is not allowed
to be overwritten, why aren't there PostGIS version specific versions
and folders for this file? Note that this error message seems related to
the "scripts" package, see error messages below.
Note that I used the 'apt' repository key as officially listed here to
get access to the installations from apt and the Synaptic Package Manager:
https://wiki.postgresql.org/wiki/Apt
This is the proper way to do this, isn't it? Or is there some other
repository I need to access?
Marco Boeringa
ERROR:
E:
/var/cache/apt/archives/postgresql-11-postgis-3-scripts_3.0.1+dfsg-2.pgdg20.04+1_all.deb:
trying to overwrite
'/usr/share/postgresql/11/applications/shp2pgsql-gui.desktop', which is
also in package postgresql-11-postgis-2.5-scripts 2.5.4+dfsg-1.pgdg20.04+1
ERROR DETAILS in Synaptic:
Preparing to unpack
.../postgresql-11-postgis-3-scripts_3.0.1+dfsg-2.pgdg20.04+1_all.deb ...
Unpacking postgresql-11-postgis-3-scripts (3.0.1+dfsg-2.pgdg20.04+1) ...
dpkg: error processing archive
(--unpack):
  trying to overwrite
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
dpkg: dependency problems prevent configuration of postgresql-11-postgis-3:
  postgresql-11-postgis-3 depends on postgresql-11-postgis-3-scripts;
however:
   Package postgresql-11-postgis-3-scripts is not installed.
dpkg: error processing package postgresql-11-postgis-3 (--configure):
  dependency problems - leaving unconfigured
Processing triggers for postgresql-common (214) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
   en_us
Removing obsolete dictionary files:
-------- Doorgestuurd bericht --------
Onderwerp: 	Problem with "undefined symbol: GEOSMakeValid_r"
Datum: 	Wed, 6 May 2020 16:56:49 +0200
Van: 	Marco Boeringa <marco at boeringa.demon.nl>
Aan: 	postgis-users at lists.osgeo.org
Hi all,
I hope someone has a recommendation for how to solve this:
When I attempted to upgrade my 19.10 Ubuntu installation to 20.04, I
first ran into an issue that I couldn't run the Ubuntu upgrade
installer, unless I uninstalled PostGIS 2.5 first. It complained about
PostGIS being on the "black list for removal" or something similar. So,
I finally decided to uninstall the PostGIS 2.5 through the Synaptics
Package manager of Ubuntu, after which I was able to upgrade to 20.04 Focal.
I then attempted to re-install PostGIS 2.5 from the Synaptic Pacakage
manager again. After several attempts, I now have it installed, and I
can access spatial data from the existing PostgreSQL 11 database using
e.g. DBeaver.
However, as part of my code, I had a call to the
"PostGIS_Full_Version()" function, and that now fails with the error
attached below. Is this still an indication the PostGIS 2.5 install is
somehow broken? I have already tried to re-install "libgdal26", as is
referenced in the error message, but to no avail.
I have also attempted to install the "postgresql-11-postgis-3" and
"postgresql-11-postgis-3-scripts" packages, in the hope of being able to
solve the issue by upgrading PostGIS, but that failed as well, with
Synaptic showing an error message and complaining about a shared library
/ application that is also in the PostGIS 2.5 install and that "could
not be overwritten" (file
"usr/share/postgresql/11/applications/shp2pgsql-gui.desktop")
Marco
SQL Error [XX000]: ERROR: could not load library
"/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
   Where: SQL statement "SELECT public.postgis_gdal_version()"
PL/pgSQL function postgis_full_version() line 34 at SQL statement
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200511/98e38425/attachment.html>
