[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri May 15 02:55:21 PDT 2020
It is mentioned in changelog and removed from the docs. For some reason
there is stray page from older release.
On Fri, May 15, 2020 at 12:52 PM Tom van Tilburg <tom.van.tilburg at gmail.com>
wrote:
> It's the first thing I ran into as well after upgrading .
> But it hasn't been mentioned in the docs? Whoops... time for an issue...
> Tom
> On Fri, May 15, 2020 at 10:56 AM Marco Boeringa <marco at boeringa.demon.nl>
> wrote:
>> Tom,
>> It now appears the PostGIS team indeed removed 'ST_Accum', but forgot to
>> update the online PostGIS Help. I see two OSGEO tickets related to this:
>> https://trac.osgeo.org/postgis/ticket/4356
>> https://trac.osgeo.org/postgis/changeset/17397
>> Both mention replacing 'ST_Accum' with 'array_agg'.
>> Marco
>> Op 15-5-2020 om 10:38 schreef Marco Boeringa:
>> Tom,
>> One more question:
>> After successfully installing the PostGIS 3.0.1 extension using CREATE
>> EXTENSION in pgAdmin4 on PostgreSQL 12.3 on Ubuntu 20.04 Focal, I now ran
>> into an issue where it appears the 'ST_Accum' function is missing in my
>> PostGIS install. My code calls this, and it failed. I then had a look at
>> the function list in pgAdmin, and indeed 'ST_Accum' is not listed. I do see
>> loads of other PostGIS functions, just 'ST_Accum' seems missing (although I
>> cannot garantuee there are a few more missing functions, but the list seems
>> pretty comprehensive from a quick look, and the CREATE EXTENSION call went
>> without a hitch).
>> Can you confirm you see 'ST_Accum' in your PostGIS 3.0.1 function list if
>> you look in pgAdmin? The PostGIS Help does not mention some deprecation of
>> this function:
>> https://postgis.net/docs/ST_Accum.html
>> Marco
>> Op 14-5-2020 om 11:42 schreef Tom van Tilburg:
>> Whatever lives in /usr/local/lib was my manual build so I had to delete
>> that manually.
>> I did  `sudo rm /usr/local/lib/libgeos*` (same for proj and sfcgal)
>> On top of that I purged all old package configurations `sudo apt purge
>> <packagename>` just to be sure but I don't think it is needed.
>> Best,
>>  Tom
>> On Thu, May 14, 2020 at 10:45 AM Marco Boeringa <marco at boeringa.demon.nl>
>> wrote:
>>> Hi Tom,
>>> Thanks for the tip, but what did you do to remove the old install? Did
>>> you rely on Apt or Synaptic to remove the old libgeos version, or did you
>>> manually clean up folders? I had two versions of libgeos as well (3.7 and
>>> 3.8) if I remember well (need to start up the VM again to check), and
>>> removed the older one through Synaptic just leaving the 3.8 version, but
>>> that wasn't enough to solve my particular issues.
>>> Marco
>>> Op 14-5-2020 om 10:32 schreef Tom van Tilburg:
>>> I think I solved it.
>>> The issue lies with gdal, not postgis (test by running `gdalinfo`), and
>>> it turns out there was an old install of libgeos (3.7) in my /us/local/lib.
>>> After simply removing all related files in /usr/local/lib gdal (and postgis
>>> and qgis) stopped complaining (I had to remove old installs of geos, proj
>>> and sfcgal for that).
>>> This issue put me on the right track:
>>> https://github.com/OSGeo/gdal/issues/2214
>>> T.
>>> On Wed, May 13, 2020 at 3:15 PM Marco Boeringa <marco at boeringa.demon.nl>
>>> wrote:
>>>> Thanks Tom,
>>>> I have seen a similar error related to the "libgdal26" library, but
>>>> that was after other trials to get something running on Ubuntu 20.04 Focal,
>>>> where I successfully installed PostGIS 2.5.4, but then encountered issues
>>>> when my code called the "postgis_full_version()" function and errored out
>>>> with the error message below related to the "libgdal.so.26" library.
>>>> However, as said, this was with PostGIS 2.5.4, not with the PostGIS 3.0.1 I
>>>> actually want to install at this moment and that gave the other error
>>>> related to the "postgis-3.so" library.
>>>> SQL Error [XX000]: ERROR: could not load library
>>>> "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
>>>> undefined symbol: GEOSMakeValid_r
>>>>   Where: SQL statement "SELECT public.postgis_gdal_version()"
>>>> PL/pgSQL function postgis_full_version() line 34 at SQL statement
>>>> Marco
>>>> Sorry for the short answer, am on the way currently. Will try to do a
>>>> decent report tonight.
>>>> Error is roughly the same but comes from libgdal26 in my case when
>>>> doing apt install qgis after an upgrade to 20.04.
>>>> best, Tom
>>>> On Wed, 13 May 2020, 14:48 Marco Boeringa, <marco at boeringa.demon.nl>
>>>> wrote:
>>>>> Thanks for the response Tom, but could you be a bit more specific?
>>>>> What do you mean with "Same problem with qgis"? Do you mean you've
>>>>> also encountered a "undefined symbol: GEOSMakeValid" error related to the
>>>>> "postgis-3.so" library when trying to use some tool in QGIS?
>>>>> I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on
>>>>> Ubuntu 20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I
>>>>> encounter the error.
>>>>> Marco
>>>>> Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
>>>>> On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl>
>>>>> wrote:
>>>>>> Hi all,
>>>>>> Is there someone who can confirm they have been able to install
>>>>>> PostGIS
>>>>>> 3.0.1 via the official APT repository?:
>>>>>> https://wiki.postgresql.org/wiki/Apt
>>>>>> After using the Synaptics Package Manager to install the three
>>>>>> packages
>>>>>> involved
>>>>>> ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>>>>>> and subsequently trying to create the PostGIS extension in pgAdmin4,
>>>>>> I
>>>>>> get the following error:
>>>>>> "/usr/lib/postgresql/12/lib/postgis-3.so":
>>>>>> /usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol:
>>>>>> GEOSMakeValid
>>>>>> I have been trying different things to fix this for past two days
>>>>>> including re-install, but to no avail. I have also attempted to
>>>>>> include
>>>>>> the UbuntuGIS repository as a potential alternative resource of
>>>>>> PostGIS
>>>>>> packages, but discovered the UbuntuGIS repository is lagging behind
>>>>>> and
>>>>>> doesn't yet have packages for 20.04LTS.
>>>>>> Marco
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>>>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/7a0e5e43/attachment.html>
