[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Tom van Tilburg tom.van.tilburg at gmail.com
Fri May 15 04:49:46 PDT 2020
On Fri, May 15, 2020 at 1:33 PM Regina Obe <lr at pcorp.us> wrote:
> Yes stray doc.  Did you find this via google.
I usually 'guess' the page by just replacing the function name in the url.
It's a very convenient way, apart from ST_Tessellate which is obviously
spelled wrong in the docs.
> Looks like that page last got updated 4/17/2019.   It’s the nature of how
> we build the docs that the updates overwrite existing for a particular
> Minor version, but don’t delete.
Makes sense, it is gone from the TOC so that is fine.
> So it existed early in the life cycle of 3.0 but was later removed
> Anyway I’ve deleted ST_Length2D_Spheroid.html and
> ST_Point_Inside_Circle.html which also seemed to have the same issue
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Darafei "Kom?pa" Praliaskouski
> *Sent:* Friday, May 15, 2020 5:55 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Fwd: Re: Broken installs for PostGIS for
> It is mentioned in changelog and removed from the docs. For some reason
> there is stray page from older release.
> On Fri, May 15, 2020 at 12:52 PM Tom van Tilburg <
> tom.van.tilburg at gmail.com> wrote:
> It's the first thing I ran into as well after upgrading .
> But it hasn't been mentioned in the docs? Whoops... time for an issue...
> Tom
> On Fri, May 15, 2020 at 10:56 AM Marco Boeringa <marco at boeringa.demon.nl>
> wrote:
> Tom,
> It now appears the PostGIS team indeed removed 'ST_Accum', but forgot to
> update the online PostGIS Help. I see two OSGEO tickets related to this:
> https://trac.osgeo.org/postgis/ticket/4356
> https://trac.osgeo.org/postgis/changeset/17397
> Both mention replacing 'ST_Accum' with 'array_agg'.
> Marco
> Op 15-5-2020 om 10:38 schreef Marco Boeringa:
> Tom,
> One more question:
> After successfully installing the PostGIS 3.0.1 extension using CREATE
> EXTENSION in pgAdmin4 on PostgreSQL 12.3 on Ubuntu 20.04 Focal, I now ran
> into an issue where it appears the 'ST_Accum' function is missing in my
> PostGIS install. My code calls this, and it failed. I then had a look at
> the function list in pgAdmin, and indeed 'ST_Accum' is not listed. I do see
> loads of other PostGIS functions, just 'ST_Accum' seems missing (although I
> cannot garantuee there are a few more missing functions, but the list seems
> pretty comprehensive from a quick look, and the CREATE EXTENSION call went
> without a hitch).
> Can you confirm you see 'ST_Accum' in your PostGIS 3.0.1 function list if
> you look in pgAdmin? The PostGIS Help does not mention some deprecation of
> this function:
> https://postgis.net/docs/ST_Accum.html
> Marco
> Op 14-5-2020 om 11:42 schreef Tom van Tilburg:
> Whatever lives in /usr/local/lib was my manual build so I had to delete
> that manually.
> I did  `sudo rm /usr/local/lib/libgeos*` (same for proj and sfcgal)
> On top of that I purged all old package configurations `sudo apt purge
> <packagename>` just to be sure but I don't think it is needed.
> Best,
>  Tom
> On Thu, May 14, 2020 at 10:45 AM Marco Boeringa <marco at boeringa.demon.nl>
> wrote:
> Hi Tom,
> Thanks for the tip, but what did you do to remove the old install? Did you
> rely on Apt or Synaptic to remove the old libgeos version, or did you
> manually clean up folders? I had two versions of libgeos as well (3.7 and
> 3.8) if I remember well (need to start up the VM again to check), and
> removed the older one through Synaptic just leaving the 3.8 version, but
> that wasn't enough to solve my particular issues.
> Marco
> Op 14-5-2020 om 10:32 schreef Tom van Tilburg:
> I think I solved it.
> The issue lies with gdal, not postgis (test by running `gdalinfo`), and it
> turns out there was an old install of libgeos (3.7) in my /us/local/lib.
> After simply removing all related files in /usr/local/lib gdal (and postgis
> and qgis) stopped complaining (I had to remove old installs of geos, proj
> and sfcgal for that).
> This issue put me on the right track:
> https://github.com/OSGeo/gdal/issues/2214
> T.
> On Wed, May 13, 2020 at 3:15 PM Marco Boeringa <marco at boeringa.demon.nl>
> wrote:
> Thanks Tom,
> I have seen a similar error related to the "libgdal26" library, but that
> was after other trials to get something running on Ubuntu 20.04 Focal,
> where I successfully installed PostGIS 2.5.4, but then encountered issues
> when my code called the "postgis_full_version()" function and errored out
> with the error message below related to the "libgdal.so.26" library.
> However, as said, this was with PostGIS 2.5.4, not with the PostGIS 3.0.1 I
> actually want to install at this moment and that gave the other error
> related to the "postgis-3.so" library.
> SQL Error [XX000]: ERROR: could not load library
> "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
> undefined symbol: GEOSMakeValid_r
>   Where: SQL statement "SELECT public.postgis_gdal_version()"
> PL/pgSQL function postgis_full_version() line 34 at SQL statement
> Marco
> Sorry for the short answer, am on the way currently. Will try to do a
> decent report tonight.
> Error is roughly the same but comes from libgdal26 in my case when doing
> apt install qgis after an upgrade to 20.04.
> best, Tom
> On Wed, 13 May 2020, 14:48 Marco Boeringa, <marco at boeringa.demon.nl>
> wrote:
> Thanks for the response Tom, but could you be a bit more specific?
> What do you mean with "Same problem with qgis"? Do you mean you've also
> encountered a "undefined symbol: GEOSMakeValid" error related to the
> "postgis-3.so" library when trying to use some tool in QGIS?
> I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on Ubuntu
> 20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I encounter the
> error.
> Marco
> Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
> On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl>
> wrote:
> Hi all,
> Is there someone who can confirm they have been able to install PostGIS
> 3.0.1 via the official APT repository?:
> https://wiki.postgresql.org/wiki/Apt
> After using the Synaptics Package Manager to install the three packages
> involved
> ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
> and subsequently trying to create the PostGIS extension in pgAdmin4, I
> get the following error:
> ERROR: could not load library "/usr/lib/postgresql/12/lib/postgis-3.so":
> /usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol: GEOSMakeValid
> I have been trying different things to fix this for past two days
> including re-install, but to no avail. I have also attempted to include
> the UbuntuGIS repository as a potential alternative resource of PostGIS
> packages, but discovered the UbuntuGIS repository is lagging behind and
> doesn't yet have packages for 20.04LTS.
> Marco
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/aecbbfd0/attachment.html>
