[postgis-users] Spatial linking or selection
Shaozhong SHI shishaozhong at gmail.com
Fri May 15 06:43:38 PDT 2020
Thanks.  Regina Obe.
I will test it.
Regards,
Shao
On Fri, 15 May 2020 at 13:44, Regina Obe <lr at pcorp.us> wrote:
> Please don’t count of autocasting of geometry -> geography.  This makes
> your code brittle as it may change in the future.
> You should explicitly cast your geometry to geography like
> ST_DWithin(a.geom::geography, b.geom::geography, somedistance)
> Or
> ST_DWithin(geography(a.geom), geography(b.geom), somedistance)
> Also keep in mind if you have spatial indexes on geometry – the above
> function can’t use them .  You’d need to add functional indexes for
> geography
> Something like
> CREATE INDEX ix_yourtable_geom_geog_gist USING gist(geography(geom));
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Shaozhong SHI
> *Sent:* Friday, May 15, 2020 8:35 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Spatial linking or selection
> Hi, Friends,
> I am a little bit confused.
> If I use geometry as data type, do I put something like 5 metres and
> *use_spheroid*=false?
> Is that correct?
> Regards,
> Shao
> On Fri, 15 May 2020 at 13:00, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
> wrote:
> Hi Shao,
> Il giorno ven 15 mag 2020 alle ore 11:56 Shaozhong SHI <
> shishaozhong at gmail.com> ha scritto:
> Hi, Nicolas,
> Thanks.
> That is very interesting.  I will test it.
> I could not find information on how distance is defined.  0.01 stands on
> what unit?
> https://postgis.net/docs/ST_DWithin.html
> Have a look to this statement in the doc you linked:
> For geometry: The distance is specified in units defined by the spatial
> reference system of the geometries. For this function to make sense, the
> source geometries must both be of the same coordinate projection, having
> the same SRID.
> For geography units are in meters and measurement is defaulted to
> use_spheroid=true, for faster check, use_spheroid=false to measure along
> sphere.
> Giuseppe.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/8a1688ae/attachment.html>
