[postgis-users] postgis-users Digest, Vol 225, Issue 6
Alain Benard alain.benard at inrae.fr
Mon Nov 16 00:46:07 PST 2020
Date: Fri, 13 Nov 2020 23:53:00 +0000
From: Devrim Gündüz <devrim at gunduz.org<mailto:devrim at gunduz.org>>
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: Re: [postgis-users] Problem raster2pgsql on Centos 8 -
        postgres 12 / postgis 2.5
Message-ID:
        <be507f72aab7462e989e799a7a4a3f8b39a75856.camel at gunduz.org<mailto:be507f72aab7462e989e799a7a4a3f8b39a75856.camel at gunduz.org>>
Content-Type: text/plain; charset="utf-8"
           On Mon, 2020-11-02 at 08:17 +0000, Alain Benard wrote:
           > I have a problem with rasterpgsql with all file geotiff.
           > On a server Centos 7 / Postgres 9.5 / postgis 2.5 :
           > /usr/pgsql-9.5/bin/raster2pgsql -b 1 -I -C -F -t 50x50 -s 2154
           > filename.geotiff tablename > script.sql       : it's OK.
           > On a server Centos 8 / Postgres 12 / postgis 2.5 : (with the same
           > geotiff file)
           >                 /usr/pgsql-12/bin/raster2pgsql -b 1 -I -C -F -t 50x50
           > -s 2154 filename.geotiff tablename > script.sql         : error The
           > script.sql file is not completed and the error is :
           >                 free(): invalid pointer Abandon (core dumped)
Can you please fully update the packages? It should pick up PROJ 7.2.0, GDAL 3.2.0, etc. This was a RPM packaging issue, and should be fixed now.
Also, can you please remove OS-supplied PROJ packages as well?
dnf remove proj-*
Regards,
Devrim Gündüz
In my case the problem persist. Perhaps i use an other depot.
For installing postgres postgis on a new virtual machine with Centos 8 i use a script:
        (https://computingforgeeks.com/how-to-install-postgresql-12-on-centos-7/)
        (https://computingforgeeks.com/how-to-install-postgis-on-centos-8-linux/)
   The principals commands are :
     dnf -y install https://download.postgresql.org/pub/repos/yum/reporpms/EL-8-x86_64/pgdg-redhat-repo-latest.noarch.rpm
     dnf -qy module disable postgresql
     dnf -y install postgresql12-server postgresql12-devel postgresql12-contrib
     dnf -y install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm
     dnf config-manager --set-enabled PowerTools
     dnf -y install postgis25_12 postgis25_12-docs postgis25_12-utils postgis25_12-client
Two version of proj are installed with the script (even if i erase proj before with ' dnf remove proj-*') :
        dnf list installed |grep proj
                proj.x86_64                                   6.3.2-4.el8                                       @epel
                proj72.x86_64                                 7.2.0-1.rhel8                                 @pgdg-common
The result : I can't use 'CREATE EXTENSION POSTGIS' :
        ERREUR:  n'a pas pu charger la bibliothèque « /usr/pgsql-12/lib/rtpostgis-2.5.so » : /usr/gdal32/lib/libgdal.so.28: undefined symbol: GTIFGetGCSInfoEx
Thank you for explaining.
Alain.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201116/65d1845b/attachment.html>
