[postgis-users] pg_restore: error: could not execute query: ERROR: function public.st_accum(public.geometry) does not exist
Regina Obe lr at pcorp.us
Thu Oct 15 01:28:32 PDT 2020
Did you install PostGIS on 2.5.2 using scripts or extension?  Those
functions shouldn't even be in your backup if you used an extension install.
It could however be complaining about references in your code to those.
Do not drop postgis 2.5.2 as that would drop your geometry and raster
columns.
If you can't upgrade the old to 3.0, do the following on new
CREATE EXTENSION postgis_raster;  -- raster was broken out of the postgis
extension in 3.0
That should fix the raster errors.
In your old database try to find in your views (I'm guessing might be where
it's coming from) reference to ST_Accum use  -- and change them to use
array_agg instead.
ST_Accum was removed in 3.0 as it's redundant and less performant than
PostgreSQL built in array_agg
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Bekir Niyaz
Sent: Thursday, October 15, 2020 4:07 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] pg_restore: error: could not execute query: ERROR:
I 'm trying restore backup from pg11 postgis 2.5.2 to pg12 postgis 3.0.0,
but restore failing.
If I drop postgis 2.5.2 on source server and install 3.0.0 will It cause the
problem ?
details:
source db (where backup taken):
     PostgreSQL 11.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5
20150623 (Red Hat 4.8.5-28), 64-bit
     POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1
27a5e771" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL
    1.11.4, released 2016/01/25" LIBXML="2.9.1" LIBJSON="0.11" RASTER
target db (where restore):
     PostgreSQL 12.4 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5
20150623 (Red Hat 4.8.5-39), 64-bit
     POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1
" SFCGAL="1.3.1" PROJ="6.2.1" LIBXML="2.9.1" LIBJSON="0
    .11" LIBPROTOBUF="1.0.2" WAGYU="0.4.3 (Internal)" TOPOLOGY
 dump file:
      Dump Version: 1.14-0
      Format: CUSTOM
      Integer: 4 bytes
      Offset: 8 bytes
      Dumped from database version: 11.1
      Dumped by pg_dump version: 12.1
example errors:
    Command was: GRANT ALL ON FUNCTION public.st_accum(public.geometry) TO
test_app;
    pg_restore: error: could not execute query: ERROR:  type "public.raster"
does not exist
    Command was: GRANT ALL ON FUNCTION public.st_countagg(public.raster,
boolean) TO test_app;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201015/fbe436bb/attachment.html>
