[postgis-users] [postgis-devel] PostGIS 3.3.0beta1 released
Imre Samu pella.samu at gmail.com
Mon Jul 4 12:41:27 PDT 2022
> I assume the geos you get from Alpine is from
> their main repo and that is why it is at
> 3.10.2, instead of the newly released GEOS 3.11.0?
Yes,
In the Alpine 3.16 repo  -> the current Geos package = 3.10.2
   https://pkgs.alpinelinux.org/packages?name=geos&branch=v3.16
And this is the current 15beta2-3.3.0beta1-alpine Dockerfile, only the
postgis will be compiled.
https://github.com/postgis/docker-postgis/blob/master/15beta2-3.3.0beta1/alpine/Dockerfile
The postgis alpine version is generally expected to have a small image
size,
   and Alpine 3.16 GEOS package is currently on 3.10.2.
( Alpine 3.17 expected in the next 6 months )
And the recommended -lto flag is not yet enabled.
( the jq based templating is planned, so it will be solved in the future )
It's not perfect yet, but I hope it will continue to get better and better
in the future.
and I will try to figure out how to make the recommended geos 3.11-based
PostGIS version. (Maybe it will be Debian based.)
regards,
   Imre
Regina Obe <lr at pcorp.us> ezt írta (időpont: 2022. júl. 4., H, 20:02):
> Much appreciated J
> One question for #2
> I assume the geos you get from Alpine is from their main repo and that is
> why it is at
> If you are building that too, can you update it to GEOS 3.11.0.
> The geos on the masters I’m happy to see are at geos 3.12dev J
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Imre Samu
> *Sent:* Monday, July 4, 2022 3:28 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] [postgis-devel] PostGIS 3.3.0beta1 released
> And the PostGIS docker images also have been updated so they are ready for
> testing:
> 1.) NEW: docker pull *postgis/postgis:14-3.3.0beta1-alpine  *
> PostgreSQL 14.4 on x86_64-pc-linux-musl, compiled by gcc (Alpine
> 11.2.1_git20220219) 11.2.1 20220219, 64-bit
> POSTGIS="3.3.0beta1 0" [EXTENSION] PGSQL="140" GEOS="3.10.2-CAPI-1.16.0"
> PROJ="9.0.0" LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.0"
> WAGYU="0.5.0 (Internal)"
> 2.) NEW: docker pull *postgis/postgis:15beta2-3.3.0beta1-alpine*
> PostgreSQL 15beta2 on x86_64-pc-linux-musl, compiled by gcc (Alpine
> POSTGIS="3.3.0beta1 0" [EXTENSION] PGSQL="150" GEOS="3.10.2-CAPI-1.16.0"
> 3.) UPDATED: docker pull *postgis/postgis:15beta2-master*
> PostgreSQL 15beta2 (Debian 15~beta2-1.pgdg110+1) on x86_64-pc-linux-gnu,
> compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
> POSTGIS="3.3.0dev 3.3.0beta1-2-ga887aab94" [EXTENSION] PGSQL="150"
> GEOS="3.12.0dev-CAPI-1.18.0" PROJ="9.1.0" LIBXML="2.9.10"  LIBJSON="0.15"
> LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
> 4.) UPDATED: docker pull *postgis/postgis:14-master*
> PostgreSQL 14.4 (Debian 14.4-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled
> POSTGIS="3.3.0dev 3.3.0beta1-2-ga887aab94" [EXTENSION] PGSQL="140"
> More details: https://github.com/postgis/docker-postgis
> Regards,
>  Imre ( docker-postgis contributor and user )
> Regina Obe <lr at pcorp.us> ezt írta (időpont: 2022. júl. 3., V, 19:11):
> The PostGIS Team is pleased to release PostGIS 3.3.0beta1
> Best served with PostgreSQL 15 beta2 and GEOS 3.11.0.
> Extra features enabled if you are running with PostgreSQL 15 and GEOS
> 3.11.0.
> The new --enable-lto flag improves math computations.  This new feature is
> disabled by default.
> Use below to enable it.
>  ./configure --enable-lto
> Details here:  https://postgis.net/2022/07/03/postgis-3.3.0beta1/
> Warm regards,
> PostGIS Development Team
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220704/671adbf7/attachment.htm>
