[postgis-users] DE-9IM pattern for gaps
Shaozhong SHI shishaozhong at gmail.com
Wed Jul 6 09:10:17 PDT 2022
How about the following situations?
Scenario 1
2 lines zigzagging over the space.  Some time, a line crosses over another
and then crosses again to return.  Can DE-9IM tell with a pattern?
Scenario 2.
2 lines zigzagging over the space.  Some time, they meet and touch each
other, but never cross each other.  There may be gaps between them.
Will there be any DE-9IM for this situation?
Regards,
David
On Wed, 6 Jul 2022 at 17:00, Martin Davis <mtnclimb at gmail.com> wrote:
> You haven't specified what you mean by "gap".  The DE-9IM model is a
> "global" model, in that it considers the input geometries as a whole.  You
> can use the DE-9IM to determine if two geometries have a "gap" between them
> via ST_Disjoint.
> On Wed, Jul 6, 2022 at 8:48 AM Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
>> Is there a DE-9IM pattern for gaps?
>> Regards,
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220706/d236733b/attachment.htm>
