[postgis-users] Help with Topology Triggers sought
Simon SPDBA Greener simon at spdba.com.au
Thu Jul 7 22:07:26 PDT 2022
Folks,
I have a topology built from two business tables containing linestrings
(pipes) and a table containing points (pits).
The business requirement means we need the topology to clean and form
common topological primitives for these lines and their nodes.
The topology will never contain polygons (faces) - should I use
pgRouting instead?
While fairly static, both tables are subject to occasional DML.
*Insert Trigger:*
A before insert trigger (trigger function - tf) handles any additions
(uses toTopoGeom).
DECLARE -- pseudo code
v_layer_id integer := 1;
   v_geom     geometry;
   v_topogeom topology.TopoGeometry;
BEGIN
   IF ( TG_OP = 'INSERT') THEN
     -- Create topology primitives for new linestring
*    v_topogeom := topology.toTopoGeom(NEW.path_line,'path', v_layer_id,
0.1);*
     -- The action of adding the linestring to the topology may see it
become slightly different from the original NEW.path_line
*    v_geom := v_topogeom::geometry;**
***    -- Then conduct the insert to the business table
     INSERT <table> (geom,topogeom) VALUES (v_geom,v_topoGeom);
     RETURN NEW;
   END IF;
END;
QUESTION: If the new linestring that is added to the existing topology
causes an existing underlying edge to change (eg split),
what happens to any other topogeom objects in the table that reference
the edge before it is changed?
Should the affected topogeoms be found and updated to reflect any splits
to edges?
I am not sure what are the best topology methods to handle updates
and/or deletes.
*Update Trigger.*
Here I want to construct an UPDATE trigger (tf) to handle situations
where points are moved or linestrings are reshaped.
In both situations the existing topogeoms point to existing topological
primitives. To handle a change should I first delete the existing
topogeom using clearTopoGeom() which modifies the underlying topology,
and then use toTopoGeom to construct the new topological primitives and
the topogeom value?
BEGIN -- pseudo code
   IF ( TG_OP = 'UPDATE' ) THEN
     -- clear any topology primitives the old topogeom uniquely referenced
     v_topogeom := topology.clearTopoGeom(OLD.topogeom);
     -- Construct new topology primitives for new linestring.
0.1);
*v_geom := v_topogeom::geometry;**
***    -- Then update the underlying topology
     UPDATE <table> SET topogeom = v_topogeom, geom = v_geom WHERE id =
OLD.id;
     RETURN NEW;
   END IF;
END;
*Delete Trigger*
Here I want to construct an DELETE trigger (tf). Is this all I need to do?
   IF ( TG_OP = 'DELETE' ) THEN
     -- Synchronize delete with underlying topology
     v_topogeom := topology.clearTopoGeom(NEW.topogeom);
     -- Then delete the record
     DELETE FROM <table> WHERE id = OLD.id;
     RETURN OLD;
   END IF;
END;
Any help/pointers greatly appreciated.
Simon
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220708/1d8d05c8/attachment.htm>
