[postgis-users] Help with Topology Triggers sought
Sandro Santilli strk at kbt.io
Mon Jul 11 00:03:51 PDT 2022
On Fri, Jul 08, 2022 at 02:50:13PM +1000, Simon Greener wrote:
> To handle a change should I first delete the existing topogeom
> using clearTopoGeom() which modifies the underlying topology
What made you think clearTopoGeomy modifies the underlying topology ?
That function ONLY affects TopoGeometry objects, which I usually
consider as being one layer ABOVE what I call the (underlying) topology.
--strk;
