[postgis-users] Library function 'pgis_geometry_union_finalfn' was deprecated in PostGIS 3.3.0
Giuseppe Naponiello beppenapo at gmail.com
Mon Oct 3 02:05:53 PDT 2022
> This means that your current "default" PostGIS version is 2.4.9,
> so "postgis_extensions_upgrade()" tries to upgrade to that version,
> but it's actually a DOWNGRADE instead.
very strange:
# apt policy postgis
postgis:
   Installed: 3.3.1+dfsg-1.pgdg110+1
   Candidate: 3.3.1+dfsg-1.pgdg110+1
I'm using a debian stable from some years, I have always used "apt" to
upgrade my packages so I never worried about version compatibility etc...
> Note the "need upgrade" message.
I noticed it, and I noticed something wrong, but I though was just
raster lib (the only 2.4.9 version of the whole stuff)
> My suggestion is to (re)install PostGIS 3.3.1 to ensure it's listed
> as the default version and run `postgis_extensions_upgrade()`.
Ok, I like it, but could there be some problem during re-installation? I
have 10 db running and I would like to avoid disasters or users panic !!
What is the correct procedure?
thanx
Il 30/09/22 17:44, Sandro Santilli ha scritto:
> On Fri, Sep 30, 2022 at 09:25:38AM +0200, Giuseppe Naponiello wrote:
>>   POSTGIS="3.3.1 3786b21" [EXTENSION] PGSQL="130" GEOS="3.9.0-CAPI-1.16.2"
>> PROJ="7.2.1" GDAL="GDAL 3.2.2, released 2021/03/05" LIBXML="2.9.10"
>> LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" (core procs from
>> "3.1.4 ded6c34" need upgrade) RASTER (raster lib from "2.4.9 r0" need
>> upgrade) [UNPACKAGED!] (raster procs from "2.4.9" need upgrade)
>> ERROR:  A stored procedure tried to use deprecated C function 'pgis_geometry_union_finalfn'
>> DETAIL:  Library function 'pgis_geometry_union_finalfn' was deprecated in PostGIS 3.3.0
>> HINT:  Consider running: SELECT postgis_extensions_upgrade()
> Great message!
>> and if I run this select I have:
>> ERROR:  extension "postgis" has no update path from version "3.1.4" to
>> version "2.4.9"
> Also, it looks like your PostgreSQL thinks the PostGIS extension
> version you have installed is 3.3.1 but you never really upgraded
> the scripts to that version (they are stuck at 3.1.4).
>> Any tips?
> Or you can do this manually by editing postgis.control (but
> re-installing is less error prone).
> Note there's a feature request issue for postgis_extensions_upgrade()
> to accept a target version, which would have helped in your case:
>    https://trac.osgeo.org/postgis/ticket/5052
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
