[postgis-users] Free Online or Cloud PostGreSQL and PostGIS
Tahir Tamba tahir.tamba at gmail.com
Sun Apr 2 20:32:01 PDT 2023
Hi Martin,
Yes Crunchy Playground is ideal for experimenting with PostgreSQL and
PostGIS as it's not persistent. However I should consider Bridge offering
in the future. I was not aware that you could subscribe for only $10 per
month.
Thank you for the tip.
Le dim. 2 avr. 2023 à 12:48, Paul Ramsey <pramsey at cleverelephant.ca> a
écrit :
> On Apr 2, 2023, at 9:44 AM, Martin Davis <mtnclimb at gmail.com> wrote:
> On Sun, Apr 2, 2023 at 7:23 AM Tahir Tamba <tahir.tamba at gmail.com> wrote:
>>  think CrunchyData is the reference for PostGIS implementation. However,
>> I don't know if it is possible to store personal data in it???
>> Brent, I would consider your offer if it does not matter for you. Let .
> The Crunchy Playground allows experimenting with Postgres and PostGIS, but
> it runs in a browser only, and doesn't persist data.
> Crunchy has the Bridge offering, which is a hosted service (PAAS) to run
> Postgres on the major cloud providers.  It's cost-effective, but not free.
> $10 / month
> https://www.crunchydata.com/pricing/calculator?provider=aws&region=us-east-1&tier=hobby&storage=10&high-availability=0
> P
> Martin
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Tahir Tamba
6632 Avenue de Gaspé
Montréal (Québec) H2S 2Y2
Courriel: tahir.tamba at gmail.com
AVERTISSEMENT : Ce courriel et les pièces qui y sont jointes sont destinés
exclusivement au(x) destinataire(s) mentionné(s) ci-dessus et peuvent
contenir de l’information privilégiée ou confidentielle. Si vous avez reçu
ce courriel par erreur, ou s’il ne vous est pas destiné, veuillez le
mentionner immédiatement à l’expéditeur et effacer ce courriel ainsi que
les pièces jointes, le cas échéant. La copie ou la redistribution non
autorisée de ce courriel peut être illégale. Le contenu de ce courriel ne
peut être interprété qu’en conformité avec les lois et règlements qui
régissent les pouvoirs des diverses instances décisionnelles compétentes de
la Ville de Montréal.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230402/735ef48b/attachment.htm>
