[postgis-users] Postgis docker upgrade error
Regina Obe lr at pcorp.us
Wed Feb 1 07:04:32 PST 2023
Devendra sorry just realized I was getting your email because I’m an owner of postgis-users.
So perhaps you aren’t registered or were unregistered because your email bounced at one point in time.
You can reregister here - https://lists.osgeo.org/mailman/listinfo/postgis-users
Regarding your question below:
I just tested and ran into the same issue.  That issue happens if when you setup your docker container, you didn’t specify a POSTGRES_USER.  I think this is a bug either in instructions or the container script not defaulting to postgres if a POSTGRES_USER is not specified when docker run is set.
Work around for that, you can specify at exec time as follows:
docker exec -e POSTGRES_USER=postgres some-postgis update-postgis.sh
Hope that helps,
Regina
From: Devendra Yadav [mailto:devendrayadavuae at gmail.com]
Sent: Wednesday, February 1, 2023 9:29 AM
To: Regina Obe <lr at pcorp.us>
Cc: postgis-users-owner at lists.osgeo.org
Subject: Re: Postgis docker upgrade error
Thanks for confirming Regina
I am able to connect via psql using postgres user
I am using the image from here - https://registry.hub.docker.com/r/postgis/postgis/
And I am running the following command to upgrade postgis  -
docker exec some-postgis update-postgis.sh
Regards,
Devendra Yadav
On Wed, 1 Feb, 2023, 6:20 pm Regina Obe, <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
This came thru fine.
1) Which docker image are you using and how are you connecting to it?
2) What command are you using – exactly to connect via psql
Can you connect by entering the docker container
Sounds like you are using the root account instead of something
psql -h localhost -p 5432 -U postgres
Thanks,
Regina
From: postgis-users [mailto:mailman-bounces at lists.osgeo.org <mailto:mailman-bounces at lists.osgeo.org> ] On Behalf Of Devendra Yadav
Sent: Wednesday, February 1, 2023 5:13 AM
To: postgis-users-owner at lists.osgeo.org <mailto:postgis-users-owner at lists.osgeo.org>
Why is it getting rejected even when I have subscribed?
On Wed, 1 Feb, 2023, 2:11 pm , <postgis-users-owner at lists.osgeo.org <mailto:postgis-users-owner at lists.osgeo.org> > wrote:
Your message has been rejected, probably because you are not
subscribed to the mailing list and the list's policy is to prohibit
non-members from posting to it.  If you think that your messages are
being rejected in error, contact the mailing list owner at
postgis-users-owner at lists.osgeo.org <mailto:postgis-users-owner at lists.osgeo.org> .
---------- Forwarded message ----------
From: Devendra Yadav <devendrayadavuae at gmail.com <mailto:devendrayadavuae at gmail.com> >
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Cc:
Bcc:
Date: Wed, 1 Feb 2023 14:11:16 +0400
Subject: Postgis docker upgrade error
Hello Experts,
I am running a docker image of postgis (latest one) from docker hub.
I am unable to proceed with postgis update. Could someone be able to assist with the error below -
Updating PostGIS extensions 'template_postgis' to 3.3.2
PSL: error connection to server on socket "var/run/postgresql/s.PGSQL.5432" failed: FATAL: role "root" does not exist
I tried passing th postgres use explicitly, didn't help.
Regards
Devendra Yadav
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230201/2225831b/attachment.htm>
